ᐅ Expanding Storage in Base Cabinets with Smart Organizational Solutions
Created on: 28 Jan 2020 08:37
Linau
Linau
28 Jan 2020 08:37
I am currently facing the challenge of significantly improving the storage space in my Ikea Metod base cabinets. In particular, I am looking for clever organizing solutions that make better use of the available space inside the cabinets—such as inserts, divider systems, pull-out elements, or similar options. I have the impression that many Metod base cabinets have a lot of unused interior space that could be made more accessible and practical through smart organization.
I am especially interested in which specific products or systems you use to maximize storage efficiency, along with your assessment of what level of effort and cost is reasonable. It would also be helpful if you could share your experiences regarding installation, handling, or everyday use.
Do you have suggestions for modular organizers that are said to fit well into Metod units? Or maybe DIY ideas that can customize and enhance the setup? I appreciate all tips!
noge58
28 Jan 2020 12:03
Great that you’re tackling this topic!
I expanded my Metod base cabinets with several pull-out drawer inserts—especially the VARIERA inserts from Ikea, which are really brilliant! They come in different sizes and fit perfectly. This gives you a really good overview, so you don’t have to spend ages searching for things.
I also use magnetic strips inside the doors for knives and small tools, which saves even more space and is very practical. A little tip: Installing the inserts is pretty quick, and once you get the hang of the concept, it’s really fun to keep organizing the cabinets better and better! So: Don’t be too intimidated by the effort—it’s definitely worth it!
KLONA
28 Jan 2020 14:27
To increase storage space in Ikea Metod base cabinets, I recommend a systematic approach that takes the internal dimensions into account.
- Modular drawer inserts that fit common widths (40, 60, 80 cm (16, 24, 32 inches)) are advantageous. Ikea offers the Variera system, which provides pull-out drawers with various compartments.
- It is generally best to optimize the use of cabinet height with multi-level inserts. This prevents wasted space between stacks and helps maintain clear separation of kitchen utensils.
- For smaller volumes, adjustable dividers or boxes that can be moved flexibly are suitable.
When assembling, make sure that the drawer inserts are securely fixed to ensure stability under load.
Investing in an organized interior not only increases visibility but also supports lasting order.
dunitan
29 Jan 2020 09:11
Hello Linau,
I can fully understand the issue, as I faced similar considerations some time ago. To make the most of the storage space in my Metod base cabinets, I installed special drawer slides and organizing boxes from third-party suppliers in addition to the Ikea Variera inserts, which often offer higher load capacity.
An important basic rule for organization is to match the frequency of use of items with the easiest accessibility: things you use frequently should ideally be stored in the front and more accessible areas.
Another useful tool, especially for deep base cabinets, are pull-out baskets or trays – these also allow access to the rear sections without having to pull everything out.
If the cabinet is very deep, rolling containers inside the drawers could also be a good addition to create even more mobility.
When assembling, precise measurements and a careful approach help – the installation instructions for Ikea products are quite useful, but sometimes you have to improvise with DIY builds if the cabinet slightly deviates from standard dimensions.
rubybi
30 Jan 2020 17:52
I would like to offer a structured suggestion on how to approach increasing storage space in Metod base cabinets:
1. Analysis of available space:
- Measure internal dimensions precisely (width, depth, height)
- Assess usage patterns: What is used frequently, what rarely?
2. Product selection:
- Ikea Variera drawer inserts for organized compartments
- Additional shelves to create layers within the interior space
- Pull-out basket systems to utilize cabinet depth effectively
3. DIY enhancements:
- Self-assembly of dividers made from wood or plastic
- Use of rubber or silicone bands to prevent slipping
4. Installation and practical use:
- Secure drawer inserts to avoid movement
- Distribute weight evenly
Common mistakes:
- Overlooking cabinet height, resulting in underutilized storage space
- Creating compartments that are too large, which encourages clutter rather than preventing it
Practical experience shows that a combination of ready-made inserts and custom modifications delivers the best results.
Kukar
31 Jan 2020 08:46
Variera inserts from Ikea are the best choice for Metod base cabinets.
Combine them with pull-out baskets and dividers. Doors can be effectively used with hooks or magnetic strips. This quickly creates more organization and additional storage space.
