ᐅ Does the Kallax unit really fit together well with the IVAR system?
Created on: 10 Nov 2015 08:23
Thiagori
Thiagori
10 Nov 2015 08:23
Hello everyone, I recently looked into the Ivar system from IKEA and am considering combining it with a Kallax shelving unit. My question is: Does the Kallax really work well together with the Ivar system? Specifically, I am interested in the aesthetic effect, the stability when both systems are combined, and whether the dimensions harmonize well enough to make a practical furniture arrangement. I would like to hear about any experiences here in the forum, especially regarding potential issues or benefits of combining them. Thanks in advance!
ladali
10 Nov 2015 09:15
The question of compatibility between Kallax and IVAR is understandable, as both systems come from IKEA but feature different construction principles and materials. Kallax is made of coated wood-based panels with fixed modular compartments, whereas IVAR is based on solid, untreated pine boards that can be assembled more flexibly.
From my experience and based on the technical dimensions, there are no direct connection mechanisms to securely fasten the two systems together. However, they can be combined aesthetically if you balance IVAR’s natural appearance with Kallax’s clean edges. Regarding dimensions, the depths are not identical (Kallax approximately 39cm (15 inches), IVAR usually 30–35cm (12–14 inches)), which should be considered when assembling them, especially if you want to achieve a flush front.
BLAKEO
10 Nov 2015 10:04
ladali schrieb:
Aesthetically, they can be combined as long as the natural look of IVAR is balanced with the clean edges of Kallax.
I agree to some extent, but I think practicality should not be overlooked. Why exactly do you want to combine the two systems? For me, the question is whether you want to link the flexibility of IVAR with the sturdiness of Kallax, or if it is mainly about the visual appeal. Without knowing the specific intended use, it’s hard to answer.
Also, keep in mind that the weight capacity and stability are higher with IVAR due to the solid wood shelves. Kallax shelves can sag if overloaded, especially the inserts. So if you plan to store heavy items or need a lot of storage space, carefully consider how you distribute the weight.
teo33
10 Nov 2015 11:46
Kallax and IVAR are not directly compatible but can be combined. Check the dimensions, pay attention to the depths, and note that no connecting parts are available. Stability must be ensured separately.
Brian
11 Nov 2015 07:38
I would like to add: When combining these two shelving systems, you should especially pay attention to the installation. IVAR is modular and allows for customized arrangements, whereas Kallax is quite rigid.
To create a harmonious look, you can use wooden elements at the same height to form a visually continuous line. Regarding stability, I recommend mounting both shelves separately to the wall rather than just placing them loosely next to each other. IVAR usually comes with pre-drilled holes and screws, which make installation straightforward. Kallax, on the other hand, is often more challenging since it’s not designed for wall mounting, but with suitable brackets, it can be done.
So, if you want to combine the systems both visually and functionally, plan the layout carefully and check the space to ensure the measurements match the room depth.
ritotar
11 Nov 2015 09:22
Hey, I tried it out at my place—Kallax and IVAR side by side in the living room. Admittedly, they’re not the perfect matching set visually; the rough, natural wood of the IVAR contrasts with the more modern look of the Kallax. But that’s exactly where the charm lies, in my opinion. 🙂
A tip: If you want to even out the height, add a few decorative items on top so both shelves visually blend together. Stability? Definitely secure both to the wall, otherwise things could tip over. This is advisable for all IKEA systems. For spacing, you can use small wooden wedges to make the edges less noticeably uneven.
So yes, they do work together if you’re willing to play around with the style a bit!
