ᐅ Does anyone else hate these loose hinges on Kallax doors?
Created on: 24 Nov 2018 14:23
mabakau
mabakau
24 Nov 2018 14:23
Does anyone else in this forum have problems with loose hinges on the doors of the Kallax shelf? I’ve noticed that the hinges become noticeably loose after some time, causing the doors to eventually not close properly or even wobble. I bought the shelf just six months ago and find it frustrating that such a simple design doesn’t come with a long-lasting solution. What bothers me especially is that, although you can readjust the hinges, the problem keeps recurring because the screws apparently go into relatively thin wood and loosen over time. Does anyone have experience with how to fix this permanently without having to buy expensive replacement fittings or completely rebuild the shelf?
praWarre69
24 Nov 2018 15:02
mabakau schrieb:
that the hinges loosen significantly over time, causing the doors to eventually not close properly or even wobble.
Oh yes, I know this problem all too well. I constantly had to tighten the doors on my Kallax unit, as if the shelf was coming to life and the screws were turning loose by themselves! 🙂 The trick I developed: occasionally apply a tiny amount of medium-strength threadlocker to the screw threads. It might sound excessive, but for just a few cents and a small tube, it’s a great solution to prevent the screws from loosening continuously.
Of course, you have to be careful not to overtighten the screws to avoid splitting the wood, but overall it’s a good balance between durability and effort. Maybe this helps you too!
elliot
24 Nov 2018 16:17
mabakau schrieb:
What bothers me especially is that you can adjust the hinges, but the problem keeps coming back because the screws apparently only go into relatively thin wood
That is correct. The construction of the Kallax shelves uses particle board-like material with a relatively thin layer where the screws are inserted. For a permanently stable hinge attachment, the screws need to be anchored in a more solid core or at least placed into plastic wall plugs.
A practical approach is to secure the screws with small wooden or plastic dowels to distribute the load. Alternatively, the screws can be replaced with longer or specially designed furniture screws.
As for tools, I recommend a cordless screwdriver with torque control to avoid over-tightening, which can further damage the material.
Unfortunately, this is a common design compromise in Kallax and many similar shelves, balancing cost and quality.
fugolo
25 Nov 2018 10:09
Here is a brief guide on how to stabilize loose Kallax hinges:
1. First, remove the door and completely unscrew the screws.
2. Apply some wood glue into the existing hole and insert a small piece of wood filler or a toothpick into the hole. Once the glue has dried, you can screw the screw back in – this will fill the loose hole.
3. Alternatively, use a plastic furniture anchor (e.g., 5mm (0.2 inch) diameter) if the hole size fits, to achieve better grip.
4. Apply a small drop of medium-strength thread locker on the screws to prevent loosening from vibrations.
5. Reattach the door and carefully tighten the screws firmly, but not too much.
The whole process takes about 30 minutes and can significantly improve stability. It is important to find the right balance between tightening firmly and not overtightening to avoid damaging the material.
If you have any further questions, I’m happy to help!
Klakar
25 Nov 2018 13:47
A brief addition: For a quick fix, you can also insert some toothpicks or matchsticks into the screw holes before screwing in the screw. This fills the hole and prevents it from loosening.
Gilbert
26 Nov 2018 08:14
Klakar schrieb:
putting some toothpicks or matches into the screw holes
This is a common trick, but it actually highlights the problem: a piece of furniture that collapses from such a simple intervention simply shows the limits of its design. I wonder why they don’t just use sturdy metal frames instead of this cheap wood imitation.
elliot schrieb:
a well-known design compromise between price and quality.
I agree – IKEA sells convenience and low prices, not necessarily long-lasting quality. Anyone who really wants something durable should invest elsewhere or, if necessary, take the trouble to make improvements themselves.
What really annoys me is this constant need for readjustment, because it’s not a technical defect but clearly a case of ‘cost-cutting.’
