ᐅ Does a 3D-printed insert really fit well into the Kallax shelving unit?
Created on: 7 Feb 2015 08:42
kennethnuK
kennethnu7 Feb 2015 08:42Hello everyone, I’d like to start a discussion on the topic: Does a 3D printer really fit well into a Kallax shelf?
Specifically, I’m interested in whether the standard Kallax from Ikea—with its typical dimensions and relatively simple design—is a good base for installing or integrating a 3D printer or all of its electronics.
I’m less concerned about simply placing the printer on the shelf and more about how well the Kallax’s structure can be adapted to accommodate the print bed, filament holder, or electronics in a neat and dust-protected way. Are there practical installation options that the Kallax design supports well? How do you handle ventilation?
I’ve already done some online research, but most solutions are DIY projects with fully custom-built boxes or shelves, or they use very large cabinets that more or less replace the Kallax.
Has anyone here had experience with this or even installed a 3D printer inside a Kallax? How satisfied are you with stability, accessibility, and usability? I also don’t want to overlook the dust issue, especially with open shelves—it seems to be a problem.
Thanks in advance for your insights and tips!
Hello kennethnu,
I believe your question is very valid and important, especially considering how much 3D printers can vary in design and size. The Kallax is originally designed as an open shelving unit and has a fairly compact depth of about 39 cm (15 inches). For many common printers, this might already be quite tight, especially if you want to allocate additional space for filament spools and electronics.
Regarding dust protection: In my experience, it’s essential to add a cover or door, particularly if the printer will be placed in a living area for extended periods. The Kallax can be relatively easily upgraded with plexiglass or wooden panels to create an enclosure. Ventilation is the key point here: good air circulation is necessary because 3D printers generate heat and sometimes odors while printing.
If you design ventilation, you should consider dust filters and a small fan to keep dust out and prevent the temperature from rising too much.
In summary: The Kallax can work if you make some modifications—adding doors, covers, and ventilation. However, it is definitely not a plug-and-play solution. If you like, I can share some tips on how to modify it yourself.
Loruli schrieb:
The Kallax is actually designed as an open shelf unit and has a fairly compact depth of about 39 cm (15 inches).Exactly, and that’s an important point, so here is my structured approach:
1. Check the dimensions: Most Kallax compartments are about 33 x 33 cm (width x height), with a depth of around 39 cm (15 inches). This means your printer generally needs to be smaller or at least not much larger, or you can use two adjacent compartments.
2. Ventilation: 3D printers need airflow, often also because of the enclosure cooling the electronics. You can make cutouts in the back panel of the Kallax (moderate openings, well protected with mesh against dust).
3. Dust protection: As Loruli said, doors or acrylic fronts help a lot. For IKEA Kallax, you can buy matching doors or make your own; even hinges can be retrofitted.
4. Stability: The shelf usually supports the printer well, but you should definitely make sure the shelf stands level and, ideally, is secured to the wall. Printers can cause vibrations during operation.
Regarding the filament holder: I recommend installing it outside the Kallax or at least in a separate compartment, so the filament is easily accessible.
In summary: A 3D printer fits quite well, but you will have to do some tinkering and modifications, especially regarding dust and ventilation.
kennethnu schrieb:
How well the Kallax frame can be adapted to properly and dust-protected house the print bed, the filament holder, or the electronics.Here’s a basic question for everyone: Is it really practical to modify the Kallax to the extent that the printer is essentially "built in"?
This often compromises accessibility, which is one of the most important features for 3D printers that frequently require manual adjustments or interventions during a print. If you close the shelf with doors or covers, you quickly risk thermal issues or hard-to-reach components.
Another point is temperature management. Open shelves allow for consistent airflow, which is important for print quality (e.g., when printing with ABS material). If ventilation is not handled properly, you risk worse print results.
I’m not generally against the Kallax, but my observation is that many people tend to just "force" the 3D printer inside without sufficiently considering ergonomic and technical requirements.
I do understand your concern about dust protection. On the other hand, it might be worth considering whether a dedicated enclosure around the printer, combined with the use of a workshop or an external air filtering system, would be more effective than modifying the Kallax.
Tause schrieb:
Modifying the Kallax so that the printer is basically "built-in"... This often compromises accessibility.I agree, 100%.
I have a 3D printer sitting on a Kallax shelf myself and use the modules below for PLA filament and tools. I haven’t altered the shelf except for adding a plexiglass sheet on top as a cover, which I can remove if needed.
The advantage of this setup is that I can access the printer freely at any time, even when I need to reach the electronics or extruder. Also, airflow remains unrestricted and dust is limited because I regularly clean the workspace.
I find the idea of doors or covers interesting, but I would definitely design them so they can be easily removed or opened.
Regarding filament: There are practical holders you can screw onto the side of a Kallax module, keeping everything compact and organized.
Does the printer fit into the Kallax?
Ultimately, that depends on the size of the printer and the space needed for peripherals.
Dust protection is easiest to achieve with a plexiglass or acrylic cover.
You should improve ventilation deliberately with small fans; otherwise, it will get warm.
You must always ensure access in case of printer issues, so avoid fixed doors that don’t open quickly.
