ᐅ Sizing of the Silencer (Helios Controlled Residential Ventilation EC 370)
Created on: 1 Jun 2017 10:26
jx7How important is the length of the silencer in the ventilation system?
Helios sells flexible duct silencers with a length of 1000 mm (39 inches) and recommends using them without shortening. In practice, however, the silencers are often cut down because the required installation space is not available. Helios considers this a common compromise but does not specify minimum lengths for effective sound attenuation.
How do you evaluate the lengths of silencers?
How long is your silencer? Are you satisfied with the noise reduction?
We have a Helios controlled residential ventilation system EC 370. Our silencer is shortened to 420 mm (17 inches) and we are dissatisfied with the noise levels.
420 mm (16.5 inches) seems very short to me. We have silencers installed that are 1000 mm (39 inches) long, plus additional silencers in front of the outlets in all bedrooms.
That is fine. However, at full power the system can already be heard quite slightly.
Then the designer dropped the ball and planned the system incorrectly. They should have made sure the installation space was available.
Andreas
jx7 schrieb:
In practice, silencers are often shortened because the necessary installation space is not available.
Andreas
Knallkörper1 Jun 2017 20:43For silencers, the sound reduction is proportional to their length. Assuming the silencer provides an insertion loss of 10 dB when uncut, it would only achieve 4.2 dB at the length you specified.
This is a simplified physical approximation, but it is practically applicable. Your setup is 6 dB louder than necessary, which corresponds to the same "loudness" as four systems with the larger silencer (logarithmically, doubling the sound power equals +3 dB).
Knallkörper3 Jun 2017 10:56Mycraft schrieb:
I have 1 meter (3.3 feet) of intake and 1 meter (3.3 feet) of exhaust, connected in series, plus another 50 cm (20 inches) of exhaust after that, but only for the upper floor, so it’s quiet enough...And where is the second silencer located? How far is it from there to the outlets?
