ᐅ Looking for a bathroom exhaust fan with humidity sensor, ducted exhaust only
Created on: 19 Dec 2022 11:33
Sinosch31S
Sinosch3119 Dec 2022 11:33Hello Everyone,
For the wet rooms (bathroom, guest toilet, and utility room) in the new build of a single-family house, only exhaust ventilation systems are required due to the conditions for "KfW 55EE". I have already had the wall openings for DN 100 installed as well as the power cables for connecting the fan (constant power).
I am now looking for an exhaust fan with the following features:
- pure exhaust air
- DN 100
- humidity sensor
- runs on constant power (no switch connection available)
- backdraft damper
- adjustable settings for run-on time and humidity level at which it turns on or off
I have already searched extensively on Amazon and read reviews and specifications. So far, I have only found one suitable option: the Lospitch bathroom fan.
Maico offers the "maico eca 100 ipro kh," but it says the settings can only be adjusted using a switch.
Do you have any additional recommendations for a bathroom fan that meets my requirements?
Greetings from Southern Hesse
- pure exhaust air
- DN 100
- humidity sensor
- backdraft damper
Helios Minivent M1/100F
Maybe this matches your requirements
Benutzer 100119 Dec 2022 11:47Where does the fresh air enter the house that the fan extracts?
Malle Zwabber schrieb:
Helios Minivent M1/100FThis model was also considered by us, but it will probably be a Lunos Silvento now. There are different circuit boards available that allow for control systems to be implemented. Maybe that could work for you.Offtopic schrieb:
Where does the fresh air enter the house that the ventilator is exhausting?The rest of the ventilation concept should definitely be considered here, but sorry, I can’t resist this one:Since this probably applies here:
- n50 = 1.5 1/h (with mechanical ventilation systems)
Sinosch3120 Dec 2022 07:42Thanks in advance for the quick replies!
Thanks for the tip!
Currently, only through the window reveal vents, so not very effective.
Sorry, I didn’t fully understand your post. We don’t have a mechanical ventilation system in the house. At our request, the energy consultant did a calculation without a ventilation system. As compensation, window reveal vents and these three exhaust devices were specified, among other things. Nothing more.
Maybe this one meets your requirements.
Thanks for the tip!
Offtopic schrieb:
Where does the fresh air enter the house that the fan is exhausting?
i_b_n_a_n schrieb:
The rest of the ventilation concept should actually be considered here as well, but sorry, I can’t help myself with this one:
Because presumably this applies here:
just due to leaks in the building 😉
