ᐅ Designing Ikea Metod Kitchen Units with Practical Corner Solutions
Created on: 3 Oct 2022 08:47
JoangaHello everyone,
I am currently planning an Ikea Metod kitchen unit for my new apartment and am encountering some challenges, especially when it comes to practical corner solutions. My main issue is that the kitchen is relatively small, and I want to make the best possible use of the available space. The key question is how to design corner cabinets and base corner units in the most ergonomic and functional way:
- What dimensions are effective to maximize the usable surface area?
- Are there any recommended corner solutions (e.g., carousel, magic corner, LeMans) that are well compatible with Ikea Metod?
- How can I plan for doors and their opening angles without losing storage space?
It is important for me that the kitchen not only looks good but also remains practical for everyday use. I would greatly appreciate constructive advice, experiences, and recommendations!
Regarding the sizing of Ikea Metod kitchen units with practical corner solutions, it is important to first know the exact measurements of the room corner. Corner cabinets are often the limiting factor, as the usable storage space in the corner is not determined solely by the cabinet width but mainly by the interior height and accessibility.
Recommendations:
- Base corner cabinets with a width of 80 cm (31.5 inches) or more usually offer a good balance between space and accessibility.
- Ikea’s "Magic Corner" is a proven solution to make the blind corner usable. However, it requires cabinet width that needs to be carefully planned.
- It is important to consider the door opening angle, especially if countertops or adjacent furniture are nearby. This affects whether smooth handling is possible.
Using CAD planning or the Ikea Kitchen Planner can help determine positions and measurements precisely. Incorrect or too tight corner solutions quickly lead to a loss of storage space and frustration.
Recommendations:
I would like to go into more detail here because when planning Ikea Metod kitchen units with corner solutions, there are many details that are not immediately obvious.
First, it is important to know that Ikea offers standardized carcasses starting at widths of 60cm (24 inches), with corner base cabinets typically measuring 80x80cm (31.5x31.5 inches). These corner cabinets have a dead space at the corner, which can be made accessible using special pull-outs or carousel systems.
- The Magic Corner, for example, is a solution where two doors open synchronously and a carousel interior fills the space. Keep in mind that the cabinet width must be at least 80cm (31.5 inches) for this system.
- Alternatively, simple rotating shelves or LeMans pull-outs can be used, although these are often more expensive and not always directly available within the Ikea system.
Dimensioning here means planning not only the width but also the depth (typically 60cm (24 inches)) and height, for example to accommodate a microwave or similar appliance.
One more important tip: the door opening direction and possible collisions with adjacent cabinets or appliances must be carefully checked before ordering. Planning with Ikea is often somewhat inflexible, so you need to know exactly what will fit from the start.
Finally: how do you use the space next to the corner cabinet? If a tall cabinet is placed immediately beside the corner base cabinet, doors can easily interfere with each other. This should definitely be taken into account when measuring.
PLOMA schrieb:
First, it’s important to know that Ikea offers standardized cabinet boxes starting from 60cm (24 inches) in width, with corner base cabinets typically measuring 80x80cm (31x31 inches).I understand that these standard sizes can sometimes be frustrating, especially when the space is unusual or limited. When I was planning, I often felt torn between Ikea’s specifications and my own requirements.
What usually helps me, especially with complicated corners, is to approach the planning step by step and repeatedly assess how practical a solution really is. Sometimes it’s worth allocating a bit more budget for custom-fit accessories that make the space more functional.
How have you handled your personal demands regarding countertop space and storage? Does anyone here have experience balancing these needs in a way that avoids feeling like too many compromises have been made?
For the question of sizing, simply keep in mind:
- Use 80x80 cm (31.5x31.5 inches) corner cabinets with Magic Corner or comparable pull-out fittings.
- Ensure there is enough clearance from adjacent elements so doors can open fully.
- Plan the depth and height so that the work surfaces align well.
In practice, Ikea Metod corner solutions with a carousel or Magic Corner offer the best compromises for small kitchens.
