ᐅ Costs of Installing a Roof Window Afterwards
Created on: 1 Jan 2021 15:54
Hausbautraum20
Hausbautraum20
1 Jan 2021 15:54
maybe someone can give me a rough idea.
We currently don’t plan to use the attic as living space, so there is only one window on the gable side and no roof windows (skylights).
However, it would be possible to gain about 35sqm (375 sq ft) of living space if we needed it later on.
Without roof windows, the back area is definitely too dark at the moment.
We are now considering whether it makes sense to install a roof window now (insulation, cladding, etc. are not finished yet, but the roof is already covered)
Or if it wouldn’t be much more expensive to simply add it later in 10 years if we definitely need it then?
Thanks in advance for your opinion 🙂
allstar83
1 Jan 2021 21:00
I’m also interested in this. Roughly estimated, a larger roof window about 140cm (55 inches) wide at KfW standard costs around 1,800 to 2,000.
Hausbautraum20
1 Jan 2021 22:11
During new construction or for retrofitting?
I was expecting to pay around 2000€ for retrofitting, but I’ve often been way off with my estimates...
1 Jan 2021 23:03
Ultimately, this is a general contractor price.
If he uses standard rates, I estimate about 1000€ for a 70cm (28 inches) wide one—the wider it is, the more expensive it gets—and then we are at the price mentioned by @allstar83.
nms_hs
2 Jan 2021 01:02
We should have had it done back then. A skylight would have cost €1000 (about $1090).
Later on, there was no offer under €1500 (about $1635).
However, you can save money by doing some of the work yourself.
Hausbautraum20
2 Jan 2021 07:44
Thanks for the information! In our case, an additional cost of €500-1000 for something we might need in 10 years (maybe?) is probably manageable. However, considering that roof windows are often said to be the easiest to retrofit, the percentage increase in price is still quite significant.
