ᐅ Number of roof windows and their placement.
Created on: 9 Nov 2023 00:01
Stein2023
Stein2023
9 Nov 2023 00:01
we are currently planning roof windows. Below you will find the attic floor plan, where the windows have been placed provisionally:
Upper floor plan with roof terrace, staircase, and living area
As you can see, there are also windows on the gable side. The roof space will be used as a studio and has no other interior walls.
Are 6 roof windows too many? Maybe you have some experience with this.
11ant9 Nov 2023 00:45
I assume this thread is now the response to my suggestion
If you mean the dormer that only appears on the eaves side view: I think you are planning something that hasn’t fully formed in your spatial imagination yet. Please show a floor plan of the attic (and especially where the potential for expansion is supposed to be). Was the basement option dropped again?
Since
Stein2023 schrieb:
we have adjusted the upper floor again
half a year ago, the staircase direction was wisely reversed, so the problematic makeshift dormer is no longer an issue. I’m curious how long this groundhog will keep popping up ;-)
kbt09
9 Nov 2023 06:43
Is the height less than 2 m (6.5 ft) where the stairs end? If so, there should urgently be a roof window directly opposite the stairs on the right side, with the width of the staircase.
The question is, what is this room going to be used for? Where is north?
Stein2023
9 Nov 2023 09:41
kbt09 schrieb:
Is it less than 2 meters (6.6 feet) high where the stairs end? Then there really should be a roof window directly opposite the stairs on the right side, matching the width of the stairs.
Hello @kbt09, it is 2.30 meters (7.5 feet) where the stairs end. A window is definitely needed there. The question is whether the windows at the top and bottom of the plan are really necessary since there are already windows on the gable side.
motorradsilke
9 Nov 2023 10:48
I would try to make the gable windows larger.
11ant9 Nov 2023 11:20
That too, yes. But above all, I would first focus on the stakeholders of possible uses and then, for example, enclose a play corridor at the stair landing. Building the entire volume merely as a heat loss issue probably wouldn’t be the best approach. The rest of the heating, ventilation, and air conditioning (HVAC) aspects would also need to be addressed: participation or non-participation in the controlled residential ventilation system, and so on.
