ᐅ Costs of Installing a Roof Window Afterwards
Created on: 1 Jan 2021 15:54
Hausbautraum20
maybe someone can give me a rough idea.
We currently don’t plan to use the attic as living space, so there is only one window on the gable side and no roof windows (skylights).
However, it would be possible to gain about 35sqm (375 sq ft) of living space if we needed it later on.
Without roof windows, the back area is definitely too dark at the moment.
We are now considering whether it makes sense to install a roof window now (insulation, cladding, etc. are not finished yet, but the roof is already covered)
Or if it wouldn’t be much more expensive to simply add it later in 10 years if we definitely need it then?
Thanks in advance for your opinion 🙂
nms_hs
3 Jan 2021 12:51
What we had to learn in the process:
- Triangular window: Unfortunately, our triangular window can only be tilted and cannot be fully opened.
- Heating connection: A duct was routed upwards from the upper floor HVAC unit. We should have used either two ducts or one larger duct from the heating unit.
- Ventilation system: We do not have a connection in the attic. So far, it works quite well. This could potentially be planned for as well.
MaxiFrett3 Jan 2021 18:57
Hausbautraum20 schrieb:
But what exactly is a triangular window?
You probably mean what is commonly called a gable window.
A triangular gable window that follows the shape of the roof.
Hausbautraum20
3 Jan 2021 19:51
Ah, okay, got it. We have "standard" windows because otherwise it was said that the shutters wouldn’t work or would be disproportionately expensive.
