ᐅ Choosing the Right Sink for a 160 cm Base Cabinet
Created on: 16 Mar 2023 13:00
JohnnyEH
we are currently considering options for our bathroom vanity and sinks.
We are planning a base cabinet 160 cm (63 inches) wide with two separate wall-mounted sinks.
What width would you recommend for each sink?
A narrower sink obviously leaves more counter space, but it shouldn’t be too narrow.
Also, we currently have a sink made of vitrified clay, and the problem is that the basin is too shallow, so water and residue don’t drain properly.
I wanted to ask the community what types of sinks you have and whether you are satisfied with them. The brand doesn’t matter much to us.
motorradsilke
17 Mar 2023 23:38
JohnnyEH schrieb:
The built-in ones have the disadvantage that in this case you also have to take the base cabinet from HA...
And unfortunately, they are only available up to a maximum width of 140cm (55 inches) – whether as one large single basin or two separate ones.
Why do you have to do that? You can buy and install the sink and base cabinet yourself.
JohnnyEH
18 Mar 2023 11:56
At least with our general contractor, this is not possible due to warranty reasons. The washbasins must be provided by the general contractor. And since integrated washbasins can only be installed with a vanity cabinet, we would also have to take the vanity cabinet from the general contractor in this case.
hanghaus2023
18 Mar 2023 13:48
Then have a few washbasins installed for 50 euros, you’ll even get a credit. 😉 I would never think of having the builder install Villeroy & Boch. But you’re right about the 1.6m (5.25 ft). That’s a special size and therefore quite expensive. Unfortunately, I can’t share the link to my result. You can find something like this for under 1000 euros.
JohnnyEH
18 Mar 2023 18:32
hanghaus2023 schrieb:
I would never consider having the builder install the Villeroy & Boch fixtures.
I don’t understand that. Why not?
If the additional cost from the builder is 300 euros per washbasin and the same washbasin costs 220 euros online, I’d rather have the builder install it directly.
Advantages:
- I don’t have to remove a washbasin from the wall afterward, which could damage the tiles
- Warranty all from one source
kati133718 Mar 2023 18:36
If the extra charge from the general contractor is 300 euros per washbasin and the exact same washbasin costs 220 euros online, I’d rather have it installed directly by the contractor.
Advantages:
- I don’t have to remove the washbasin from the wall later and risk damaging the tiles
Well, the extra charge is 300. But if you decided to remove it yourself from the contractor, they would probably credit you for the standard washbasin? So the price difference is actually much higher.
JohnnyEH
18 Mar 2023 18:39
No, that’s not possible.
I can’t remove the washbasin at the general contractor’s. The general contractor insists on installing a washbasin for warranty reasons.
