ᐅ Connection of External Cameras
Created on: 27 Mar 2016 18:58
V
Vip3r86
V
Vip3r86
27 Mar 2016 18:58
I would like to include two IP cameras for monitoring the outdoor area in our new build. One option could be the Instar 5907. Now I’m wondering what should be specified regarding the electrical planning.
So far, I assumed that installing outdoor power outlets at the planned camera locations would be the most practical solution. However, the downside is that this results in quite a bit of visible cable clutter outside, including the power adapters, which in my opinion is difficult to conceal. Additionally, this setup would require a Wi-Fi connection.
Another option I’m considering is having empty conduits installed and running the camera cables through them. This would make the wiring completely invisible from outside. Also, the network connection could then be established directly via Ethernet cable.
Do you have any tips on which solution would be preferable?
Mycraft27 Mar 2016 20:14
About PoE without an additional power supply... but consider whether two cameras are sufficient... I would simply run two CAT cables from the utility room to two opposite corners of the house.
