ᐅ Connection Between Driveway/Lawn and Facing Bricks
Created on: 12 Mar 2017 22:07
nms_hs
nms_hs
12 Mar 2017 22:07
Good evening,
I have two small issues.
Point 1:
- The landscaper installed the driveway directly against the brickwork and then filled the joint with sand. The site manager says there should have been at least a “expansion membrane” or something similar in between to prevent noise transmission (similar to the blue sheet used under screed).
Does anyone know the current standard practice for this?
Point 2:
- In the areas without a terrace or driveway, topsoil/grass was placed directly up to the bricks. I’ve heard rumors that this might be bad for the masonry in terms of moisture.
Can anyone confirm or refute this? Is it just an aesthetic issue?
I have attached two photos. Thanks in advance for any advice :-)
Regards,
Simon
Exterior area of a house with stone slab path, grassy areas and hose on the wall
Exterior wall made of red bricks next to a grey paved surface; visible joint between wall and ground
Nordlys
12 Mar 2017 22:13
About the paving. No idea. I also don’t like the idea of having just grass. There should be a gravel strip or pebble strip next to the house, then the grass.
nms_hs
13 Mar 2017 19:06
Yes, I would also prefer that visually. However, the question I have is: Do I need to do this from a technical point of view this year, or can it wait until next year? :-)
13 Mar 2017 20:13
nms_hs schrieb:
Yes, I’d also prefer that visually. The question I have is: Do I need to do this from a technical standpoint this year, or can it wait until next year? :-)
Who’s talking about appearance here???
The area with the lawn can be done by two people over a weekend... the year is just starting, which builder would still hesitate to order the gravel?
Regards, Yvonne
nms_hs
14 Mar 2017 16:45
The area with the lawn can be done by two people over a weekend... the year is just starting, which homeowner would still hesitate to order the gravel?
Regards, Yvonne
The one who still has to level the lawn in the back, build the second garden shed, the rear fence, the climbing frame/swings (and who knows what else) :-)
Has anyone else installed the paving stones directly against the brickwork? Did anyone place an expansion membrane in between?
ph710
19 Mar 2017 08:47
We have the gravel strip all around the brickwork.
I would take care of that first from your list.
