ᐅ Carport with a sturdy storage shed
Created on: 22 Aug 2019 11:43
pffreestyler
now that we have completed construction and moved into our new home, we are probably in the fortunate position to add a carport with a solid shed.
Since we hadn’t planned for this financially before construction started, we have only looked into the topic superficially so far. I have already requested an appointment with the shell builder and don’t want to go there unprepared.
To my knowledge, in Schleswig-Holstein a 9m x 6m (30 ft x 20 ft) structure does not require a building permit / planning permission. We want to make full use of the length, but we cannot fully use the width.
We are thinking of dividing the length into 5m (16.5 ft) for the carport and 4m (13 ft) for the shed.
Here are some questions we have:
1. Gable roof: Why choose a gable roof at all? -> For storage space, e.g., garden furniture, car tires, etc. But we are basically open to alternatives, although none really come to mind. We are struggling with the height and the roof overhang. Preferably both should be as low as possible, as long as it remains practical. I am 1.94m (6 ft 4 in) tall and would like to be able to stand straight up in the middle under the roof. However, this is not a must if something else makes more sense. Our house is 8.5m (28 ft) high and has a roof pitch of 45°. So the roof pitch should only be reduced enough that both roofs still look harmonious. The roof overhang should be kept quite small, e.g., about 30cm (12 inches), so the shed does not get too close to the patio door.
2D-Hausgrundrissplan mit Terrasse und Garten
2. Shed material: The shed will not be insulated but should have a facing (cladding). We also want a concrete slab foundation instead of paving. The most practical material for the thinnest wall is probably wood, but I would rather avoid that. What would be an alternative? We could install Ytong (aerated concrete blocks) ourselves, but is another material more suitable? Wall thickness would probably be 17.5cm (7 inches) Ytong + 11.5cm (4.5 inches) facing. This would reduce the usable interior space from roughly 20m² (215 sq ft) outer dimensions to about 17m² (183 sq ft).
3. Positioning:
This is roughly what we have in mind:
Schwarz-Weiß Bauplan-Grundriss mit nummerierten Feldern und roten Markierungen
We will probably have to “set back” the shed a bit towards the house as shown above. The distance to the patio door is 1.74m (5 ft 9 in), which we naturally do not want to fully use up. Although the house is exactly 5m (16.5 ft) away from the property boundary, the shed will have to be set back because of the roof overhang if we want to keep that 5m distance. Does this make sense to you and seem reasonable?
Probably a bit confusingly written, but I hope it is at least somewhat clear.
pffreestyler
5 Mar 2020 09:25
I need to bring up this topic again: the offer was made in October. Construction was scheduled to start at the end of March/beginning of April. Now there is a problem because the supplier no longer stocks the facing bricks, and the remaining bricks we have are not enough. Unless we manage to obtain the bricks through alternative channels, I need to consider other options. The carpenter suggested fiber cement panels from, for example, James Hardie. According to a friend, these panels are quite prone to impact damage. Does anyone have experience with these panels and can possibly alleviate my concerns?
11ant5 Mar 2020 15:15
pffreestyler schrieb:
Now there is the problem that the supplier no longer carries the facing bricks in their range.
If they are also out of stock with the manufacturer and will not be reissued, other suppliers will likely be even more eager to sell any remaining stock. Otherwise, if I remember correctly, you can only aim for a matching look with the house, but there is no direct connection (which actually gives you some flexibility to choose the desired color tone in a different format).
pffreestyler
5 Mar 2020 15:48
A similar brick is out of the question, as that would bother us. Therefore, we want to proactively look into alternatives. Wood is not an option for my partner.
So the question is about experience with fiber cement panels. I do have samples at home, but real-life experience is more telling.
11ant5 Mar 2020 16:28
A similar facing brick is out of the question, [...] Hence the question about experience with fiber cement panels.
But aren’t fake brick slips even less similar???
pffreestyler
5 Mar 2020 16:40
Fiber cement panels are available in the color of our windows, and these are not fake cladding strips; in fact, they are also available in lengths of 4 meters (13 feet).
11ant5 Mar 2020 16:44
Oh, so these are not options aiming to resemble the brickwork of the house, but rather intended to avoid adding a third color to the overall design (?)
