derstefanm28 Jan 2015 07:27Hello, we are currently in the planning phase for the construction of a detached single-family house in Owl. Now the question inevitably arises whether the exterior facade should be finished with a single-layer render with an external thermal insulation composite system (ETICS) or a two-layer facade with Dutch-style facing bricks. Our target is a KfW 70 energy standard. We had basically decided on bricks because they allow better breathability and I have not been particularly impressed with tightly sealed render facades so far, especially regarding maintenance. However, a builder recently told me that there are render facades that can last 30 years with the first coat of paint. Combined with an air-to-water heat pump and integrated mechanical ventilation, this would be acceptable. Additionally, the cost for a render facade is about 10,000 to 15,000 euros less than for a brick facade.
So, my question is: which ETICS setup is the most durable, not only considering the insulation material but also the render and paint? That also plays a significant role.
Thanks in advance for your answers....
nordanney28 Jan 2015 08:58derstefanm schrieb:
. We had basically already decided on brickwork because it "breathes" much better, and so far I have not been very impressed by sealed rendered facades, especially regarding maintenance. Since when do bricks breathe?B
Bauexperte28 Jan 2015 10:24Hello,
From our experience, the degree of soiling and cleaning possibilities depend significantly on the house’s orientation on the lot and the number of floors. For example, if the weather-exposed side faces north and the garage is located there as well, and it is a typical single-story building, regular cleaning of the north façade with a pressure washer is usually sufficient. This is easy for a homeowner to manage, even for someone not very handy.
It is different if the building—which I don’t really see for OWL—is located in a coal or industrial area. In such cases, a brick veneer won’t help much either; it just creates the illusion of a "clean" façade. Because even brick absorbs rainwater, then dries, trapping dirt inside. That’s why especially white brick facades often look "dirty" after a short time.
Regards, Bauexperte
derstefanm schrieb:Interesting statement
We had basically already decided on brick veneer because it "breathes" much better.
derstefanm schrieb:These statements have been around for a long time; however, I don’t consider them very reliable. You can increase durability with a fungicidal-algicidal coating; these coatings are also available in eco-friendly versions. When calculating cost-effectiveness, you should always compare the costs of brick cladding with the expected repainting intervals of a plaster facade; construction method does not belong in this comparison.
But a contractor recently told me that there are plaster facades which can last 30 years with the first coat of paint.
Regards, Bauexperte
derstefanm29 Jan 2015 03:42By "breathing," I mean that a cavity wall construction combined with clinker brick is more vapor permeable and can transport moisture more effectively.
What about the insulation material; are there differences in terms of durability? Is the coating the only crucial factor?
DerBjoern29 Jan 2015 10:48You can ignore moisture diffusion through the walls. Not even 1% of the moisture generated inside the house diffuses out through the walls. Whether it’s 0.3% with brick veneer or just 0.2% with external thermal insulation composite systems (ETICS) makes hardly any difference. Moisture only leaves the house through drainage and ventilation!
