ᐅ Is it possible to apply adhesive film to IKEA Metod cabinets yourself?
Created on: 24 Oct 2021 09:12
padorina40P
padorina4024 Oct 2021 09:12Hello everyone, I am considering applying an adhesive film to my IKEA Metod cabinets myself to give them a more customized look without having to buy new doors each time. My question is: Is it possible to apply a film to IKEA Metod cabinets without it bubbling, peeling, or causing other issues shortly afterward? I have done some research and understand that Metod cabinets generally have a relatively smooth surface, but it doesn’t seem to be completely smooth, which makes me a bit unsure. Has anyone had experience with applying film to Metod cabinets, possibly with tips on suitable materials or techniques? Are there specific types of films or textures that adhere better? I don’t want to just put on any film that ends up looking like a poor DIY job after two weeks. Thanks in advance for your insights and advice!
Yes, you can apply adhesive film to Metod cabinets yourself. It is important to thoroughly clean and degrease the surface. It is best to use a high-quality self-adhesive film suitable for furniture. Bubbles usually occur only if the film is stretched incorrectly during application.
Hello padorina40, your question is very good and important, especially if you want to make long-lasting changes to the cabinets. The IKEA Metod cabinets usually have a melamine resin-coated surface, which is smooth but not as perfectly even on a microscopic level as lacquer or glass. First, thorough cleaning and dust removal are essential to ensure the film adheres well. Films that are specifically designed for furniture and kitchen surfaces—meaning water- and heat-resistant—are highly recommended. When applying the film, it helps to use a squeegee and apply the film gradually to avoid air bubbles. I have applied film to cabinet fronts myself, and it works well if done carefully. One tip: for edges, it’s best to choose a film that has some stretch or to trim the corners beforehand.
Hello padorina40, I’m taking the time to explain the topic in detail. Wrapping IKEA Metod cabinets is generally possible but requires some considerations if you want a professional result. First, regarding the surface: Metod cabinets have a melamine resin-coated surface, which is smooth but slightly textured. This means you must carefully clean and degrease the surface before wrapping, ideally using an alcohol-based cleaner. The surface is not painted but rather a type of HPL layer, which supports the adhesive of the vinyl as long as everything is clean.
About the material: I recommend high-quality PVC vinyl films specifically designed as furniture wraps, typically 70–100 µm (micrometers) thick, with matte or satin finishes. The choice of vinyl often determines durability and appearance. When applying, peel the backing from one side, and use a soft squeegee and a heat gun to fit the vinyl around edges. Take your time with edges — warming the vinyl a bit makes it more flexible and allows you to neatly fold it over edges without risking tears. Applying it manually really requires patience to avoid bubbles, especially on larger surfaces.
One last tip: Never stick multiple vinyl layers on top of each other, as this reduces durability and detracts from the look. In conclusion, if you do it carefully, the vinyl will hold well and look good. Are you planning to wrap the doors completely or just change individual panels? And which color or finish do you have in mind?
padorina4024 Oct 2021 15:45Laukau5 schrieb:
One last tip: Never stick multiple sheets of film on top of each other, as the result won’t be durable and the appearance will suffer. Thanks, good advice! I mainly want to cover the fronts completely with film, as I’m no longer happy with their current look. I’m interested in a matte surface in dark anthracite. Do you or anyone else have recommendations for manufacturers or specific films that are especially suitable for kitchen fronts? Also, I wonder if such a film is relatively heat-resistant, since the fronts are right next to the stove.
