ᐅ Can I retrofit or replace the drawers of IKEA Brimnes furniture myself?
Created on: 18 Jul 2019 17:43
Gamathias
Gamathias
18 Jul 2019 17:43
Hello everyone, I am currently planning to upgrade my IKEA Brimnes dresser by replacing some of the drawers. I have a question: Is it possible to retrofit or replace the drawers of this model without having to change the entire piece of furniture?
I am particularly interested in issues such as the compatibility of replacement parts, whether IKEA sells these individually, and if the construction allows for swapping out only certain drawers.
Additionally, I would appreciate any advice on the tools required for this and if there are any specific details to keep in mind when removing the drawers.
Has anyone had experience with this or can offer specific tips on the best way to proceed? Thanks in advance!
PEDRO40
18 Jul 2019 19:02
Gamathias schrieb:
Can I retrofit or replace the drawers of this model myself without having to replace the entire piece of furniture?
This is actually a topic I was a bit uncertain about myself when I wanted to replace one of my Brimnes drawers some time ago.
From my experience: yes, it is possible to replace drawers individually, but it largely depends on whether you can get original parts or have to rely on retrofit solutions. IKEA often doesn’t sell all individual components separately, so it can be difficult to get exactly the same drawer or a compatible replacement.
For removal, you basically only need a screwdriver for the tilt latches on the drawer slides. It’s important to handle the runners carefully to avoid damage, otherwise the drawer might not slide smoothly afterward.
At the time, I tried to replace a drawer with a custom-built insert, which caused some minor issues because the dimensions didn’t fit exactly. So if you can find original parts or plan an official retrofit, it will be easier.
If you like, I can provide a more detailed description later about how I proceeded and what stumbling blocks I encountered.
TAUPLO
19 Jul 2019 08:36
PEDRO40 schrieb:
IKEA often doesn’t sell all individual parts separately
Exactly! IKEA can make it quite challenging sometimes 😊 I once tried to order a replacement drawer for my Brimnes – no luck!
Fortunately, the drawers in the Brimnes series are quite modular, meaning you can usually remove them, inspect them, and even repair or update them a bit.
My advice: When looking for replacements, keep the dimensions and construction in mind in case you need to rely on third-party parts or DIY solutions. This will save you headaches and sighs during assembly later on.
And remember: you don’t always have to replace the entire piece of furniture; often, a fresh interior can make it feel like new again.
KODAN32
19 Jul 2019 12:21
I have systematically summarized my experience with the Brimnes chest of drawers:
- In principle, the drawers of a Brimnes chest of drawers can be removed and replaced by yourself, as the slides are standardized and matched to the furniture.
- Official replacement parts from IKEA are very limited, often only entire drawer fronts or complete drawer boxes, but no individual internal components.
- Important when removing: pull the drawer out completely, press the tilt levers on the sides, then pull it out together with the sliding rail.
- Retrofitting with other drawers requires matching dimensions and attachment points exactly; otherwise, fitting problems may occur during installation.
- Tools needed: Phillips screwdriver and possibly a small flathead screwdriver to release the tilt levers.
- When replacing, always check the glides and slides, as wear can strongly affect functionality.
If you work on it yourself, I recommend keeping the original screws and all small parts so nothing is missing when reversing the process.
In summary: you can replace individual drawers, but success depends on the availability of replacement parts. If you can’t get original drawers, carefully check dimensions and fittings to avoid frustration during installation.
If needed, I can gladly provide a step-by-step guide for removal and installation.
