Created on: 27 May 2019 10:48
goalkeeper
goalkeeper
1 Jan 2020 08:37
OWLer schrieb:
If the coffee machine really goes into the corner niche, refilling the water tank will be a very frustrating task.
Not really – the water tank can be removed. In our current kitchen, it’s also located under a wall cabinet, though that one hangs even lower.
Fummelbrett!
1 Jan 2020 13:01
With our machines, the issue would not be the water tank at this position, but rather refilling the beans.
tomtom791 Jan 2020 13:16
You just line it up, move it into place, and that's it.
goalkeeper
2 Jan 2020 20:23
We will now move the tall cabinet side slightly forward to create enough space for the dishwasher door.
This way, we won’t have to make any changes to the sink side and can keep the 30cm (12 inches) pull-out pantry. We simply didn’t like the two 15cm (6 inches) units, and the sink would have shifted too far to the right.
Thanks again to @kbt09 for the valuable tip.
Top view of a kitchen: wooden floor, stove on the left, sink at the bottom, wine rack on the right.
kbt09
3 Jan 2020 09:19
Ok, if there was still some space left.
The kitchen showroom will probably come for the actual on-site measurement at some point. Just make sure to check everything again then. You already know the critical point.
Climbee3 Jan 2020 10:47
I don’t see the point of having a side-by-side refrigerator built into a kitchen unit – you can get a built-in fridge with the same functions, and then you don’t have the problem of it protruding. That would be my solution.
But I know some people really want a side-by-side fridge – so let it be.
Instead of the built-in microwave, I would recommend a combination oven with microwave function – the functionality is much more extensive! I still don’t understand why a separate microwave is needed, but that’s just my personal view. That’s why I have a combination oven with baking function, although there are models with microwave features as well. I definitely wouldn’t want to do without the combination oven. The installation dimensions remain the same, so the kitchen planning doesn’t need to change (unless the combination oven requires a fixed water connection).
The handles look stylish, but as a cooking enthusiast, they wouldn’t work for me – I need to have at least two kitchen towels handy while cooking, and that’s just not possible with these handles. Think about whether you really want that. If yes – as I said, they do look great!
By the way, I’m not really a fan of photo splashbacks either – but they are easy to replace *grin*. I like the stone (Nero assoluto flamed?), but using it throughout the entire niche would be a bit too dark for me; it looks somewhat like a crypt. Definitely plan some niche lighting! Alternatively, I would not extend the splashback panel all the way up to the upper cabinets, but leave a section of white wall in between; only pull the splashback behind the stove up to the upper cabinets. That also helps to brighten things up.
