ᐅ Poor Plastering Work or Proper Application of Wall Plaster
Created on: 16 Jun 2021 23:21
Bender
The wall construction in the stairwell shows bulging joints at the transitions between floors. I wonder if this is a technical necessity and unavoidable, or if the problem is related to poor workmanship.
The side walls in the stairwell are built from 100mm (4 inch) thick gypsum blocks with tongue and groove joints. These were leveled with approximately a 0.5mm (0.02 inch) layer of plaster, then covered with a non-woven wallpaper. The non-woven wallpaper was treated, and the bulges were repaired with a finishing plaster. The finish was supposed to meet Q3 quality standards. The entire surface was then treated against chalking and painted over. At the joints between floors (where the bulges are), only a perforated metal profile can be seen, which is typically used for corners in drywall construction.
When cutting open the wallpaper, the plaster crumbled completely, and the paint peeled off from the wallpaper. I am attaching some pictures and would appreciate your feedback. In my opinion, this issue is still subject to a claim.
Holztreppe vor heller Wand, Wand mit dunklen Flecken und Schlieren.
Weiße Wand mit diagonal verlaufender Kante, links Holzrahmen, Schatten darüber.
Nahaufnahme einer beschädigten Putzwand mit abblätterndem Putz und Rissen.
Nahaufnahme einer beige gestrichenen Wand mit abgeblättertem Putz und Rissen.
evelinoz
19 Jun 2021 07:11
I wonder how it looks in other areas of the house, whether the tile wallpaper is holding the plaster firmly to the wall everywhere.
Bender20 Jun 2021 09:25
The areas shown are visible on all levels between the floors, but only in the stairwell, where no load-bearing solid wall is present (e.g., transition between ground floor / 1st floor, transition 1st floor / 2nd floor). It is an open stairwell with a staircase running from the basement to the 2nd floor. The developer said at the time that there was no other way because different materials meet here. Therefore, I decided to cut open one spot before the warranty expires. To be honest, I can’t really identify different materials.
In other places, we don’t have such transitions, where the gypsum board walls are only installed floor to ceiling. So far, we actually had the problem in another room that the plaster behind the wallpaper detached. There was about a 1cm (0.4 inch) thick layer. The detached plaster was removed and replastered. All the tiled wallpapers were taken down, then new ones applied, and everything repainted afterward. (All under warranty, of course).
