ᐅ Filling Scratches in BILLY Shelving – Suitable Materials?
Created on: 7 Apr 2016 18:23
bruce70
bruce70
7 Apr 2016 18:23
Hello everyone, I have a Billy bookshelf from IKEA that unfortunately has some scratches on the white laminate surface. I would like to repair these damaged spots myself, but I have no experience with filling scratches on this type of shelving. My specific question is: which material is best suited for filling the scratches so that they are barely visible afterwards and the surface remains as smooth as possible? Should I use a special filler for wood or for laminate? Is there maybe a trick when choosing the material to prevent cracks or the filler from peeling off later? I look forward to your tips and experiences!
Sepele
7 Apr 2016 18:57
bruce70 schrieb:
Which material is best suited for filling scratches so that they become barely visible afterward and the surface remains as smooth as possible?
Hello Bruce, I’m familiar with this issue and generally recommend a very fine polyester or epoxy filler specifically designed for furniture and laminate. These fillers are elastic enough to prevent cracking or peeling.
Instructions:
1. Lightly sand the scratches to slightly roughen the surface.
2. Clean quickly to remove dust and grease.
3. Apply the filler thinly, preferably with a small plastic putty knife, and spread it evenly.
4. After drying, sand very finely (grit 400 or finer).
5. If necessary, touch up with matching acrylic or lacquer paint.
Common mistakes:
- Applying too thickly causes cracking.
- Not sanding after drying ruins the appearance.
If you need an exact color match, I also recommend testing a small filler sample on an inconspicuous spot. Good luck!
NICOLELIS
7 Apr 2016 19:12
bruce70 schrieb:
Which material is best for filling scratches so that they become almost invisible afterward?
Wood filler for laminate or fast-drying canvas filler. Important: Apply in thin layers, otherwise it will crack.
reybo
7 Apr 2016 20:09
Sepele schrieb:
I generally recommend a very fine polyester or epoxy filler
That is absolutely correct. I would like to add that for BILLY shelves, the laminate is a thin plastic coating on a particleboard core. Therefore, you should make sure that the filler material adheres well and bonds properly with the substrate.
Also very important is sanding between layers after drying. If this is not done adequately, you often get an unsightly edge or unevenness that cannot be smoothed out with paint later on.
One more tip: if you want to perfectly match the color, repair kits for laminate furniture are useful; they include color markers and special pastes. These work well together with filler, especially if you have lightly sanded the repair area beforehand.
I would also be interested to know the exact size of the scratches, since for very small surface damages a furniture touch-up pen or matching varnish might be sufficient. If you like, you can share that information, and I will be happy to offer you a tailored solution.
bruce70
7 Apr 2016 21:03
Thanks already for the detailed tips! The scratches are quite narrow, but in some places up to 5cm (2 inches) long. So not just small marks, but actual lines that you can also feel when you run your finger over them. I want to prevent these spots from standing out too much, but a perfect invisible repair will probably be difficult.
reybo schrieb:
If you like, you can add that, and I’ll happily offer you a tailored solution.
If you have any ideas on the best approach for edges or longer minor dents in laminate flooring, I would be very grateful.
matthewon
8 Apr 2016 08:27
bruce70 schrieb:
The scratches are quite narrow, but in some places up to 5 cm (2 inches) long.
It sounds like the advice here is a bit over the top. Why make it complicated when you can simply paint over it?
In my opinion, using filler on furniture like this often just wastes time and rarely looks noticeably better. The paint from the home improvement store usually provides excellent coverage.
Such fillers are often just an intermediate step that’s hardly necessary for small scratches. Maybe try a color-matched touch-up pen first? If the layer isn’t too thick, it often looks very natural and saves a lot of effort.
