ᐅ Filling Scratches in BILLY Shelving – Suitable Materials?
Created on: 7 Apr 2016 18:23
bruce70
Hello everyone, I have a Billy bookshelf from IKEA that unfortunately has some scratches on the white laminate surface. I would like to repair these damaged spots myself, but I have no experience with filling scratches on this type of shelving. My specific question is: which material is best suited for filling the scratches so that they are barely visible afterwards and the surface remains as smooth as possible? Should I use a special filler for wood or for laminate? Is there maybe a trick when choosing the material to prevent cracks or the filler from peeling off later? I look forward to your tips and experiences!
nausu
8 Apr 2016 11:16
matthewon schrieb:
In my opinion, filling putty on such furniture is often more of a time sink
I see this more nuanced. For BILLY shelves with laminate surfaces, the durability of the repair is crucial. Just using paint or a marker is not always enough for deeper scratches because the surface does not remain smooth.
A technically appropriate approach is:
- Pretreatment by sanding or cleaning the damaged area
- Use of a fine, flexible plastic filler
- Refinement by fine sanding
- Color matching with paint or marker
This ensures that the repair is mechanically durable and visually appealing.
Therefore, filling putty is not an unnecessary effort but a step to guarantee lasting quality.
NAU34
9 Apr 2016 13:44
Hi Bruce, I can only agree with the practical tips and would also recommend using a water-based acrylic paint for color matching. It applies easily and dries quickly.
Once the filler is completely dry and well sanded, simply apply the paint carefully in small amounts to avoid running.
For those who like to experiment: you can also mix the paint with a touch of pigment from a small artist’s paint set to match the shade even better.
Sounds like a great little project, good luck! 🙂
