ᐅ Replacing Plastic Components on a BILLY Shelf – How and Where?
Created on: 7 Oct 2015 10:27
reole
reole
7 Oct 2015 10:27
I have a Billy shelf from IKEA, where unfortunately some of the plastic components, especially the shelf supports (also known as dowels or clips), are damaged or broken. Now I want to replace these plastic parts to restore the stability and safety of the shelves. However, I’m unsure how to best find the right replacement parts or where to order original or compatible ones.
Also, I’m interested in how to properly carry out the replacement – are there any tips or special tools needed? Perhaps some of you already have experience with changing plastic parts on BILLY shelves?
I would really appreciate any advice on sourcing the parts as well as guidance on correct repair methods. Many thanks in advance!
alvalo
7 Oct 2015 11:43
Hello reole,
First of all, a warm welcome to the forum! 🙂 I had exactly the same problem with my BILLY shelves. The small plastic clips or shelf supports can actually be obtained either directly from IKEA as spare parts or from various online spare part shops; sometimes you can also find them on eBay. It is important that you have the exact name – often the assembly instructions specify the exact name of the part.
When replacing them, it’s helpful to carefully remove the old damaged parts, which usually can be done with a small screwdriver or a knife to pry them out. Be careful not to damage the wood or the side panels. You simply click the new supports back into the pre-punched holes. A small rubber mallet can be useful if the parts don’t go in quite easily.
If you still have the instructions, check the section on assembling the shelf and the corresponding parts. If anything is unclear, feel free to ask!
Good luck with the repair!
sonrickey
7 Oct 2015 14:09
Hey reole,
"How and where to replace plastic parts for the BILLY shelf?" – a real DIY adventure question! 😉
I’ve also replaced a few of those plastic clips because those little things tend to break easily when you don’t notice. IKEA doesn’t always have all spare parts in stores, but just try ordering replacement parts online at ikea.com or contact customer service – that usually works great. If that doesn’t work, hardware stores or online platforms like Amazon or eBay offer compatible parts as well.
You basically only need a small screwdriver and some patience; sometimes a small hammer helps, but be gentle! Especially if the old parts are stuck or tight. And don’t worry if it feels a bit loose the first time – you can usually adjust it a bit afterwards.
Have fun tinkering! 🙂
Klakar
7 Oct 2015 17:58
alvalo schrieb:
You simply click the new beams back into the pre-punched holes.
Exactly. Order parts from IKEA, pry out the old ones, put the new ones in. Nothing complicated.
HORST41
8 Oct 2015 08:36
I can confirm that installing the new plastic parts into the BILLY shelf usually works smoothly. However, I would also like to mention that some shelves may be slightly warped, which can make snapping the parts back in a bit more difficult. In such cases, I once received the tip to gently roughen the holes a little with some sandpaper or a file.
Klakar schrieb:
Exactly. Order the parts from IKEA, pry out the old ones, put in the new ones.
That sums it up well—just with a bit of patience, it works perfectly.
I know it’s frustrating when you first notice wobbling or slight signs of damage, but with the correct parts, you’ll really enjoy your shelf again. If you’re unsure whether the parts still fit your shelf, you can ask IKEA for the exact part number over the phone.
Good luck, and please keep us updated!
DUKUSU
9 Oct 2015 12:02
Hello reole and all other shelf fans! 🙂
It’s great to see so much helpful advice here about BILLY shelves! I’ve been in the same situation myself and can confirm that tackling a project like this is really motivating.
sonrickey schrieb:
IKEA itself doesn’t always have all spare parts in their stores, but simply ordering spare parts online at ikea.com or contacting customer service usually works really well.
Exactly! And if you get stuck while removing parts, just remember: use gentle leverage and avoid applying too much force at once – that way you reduce the risk of anything breaking or splintering.
What also helped me was that if the plastic parts are older and brittle, it’s best to replace them completely, as partial replacement can otherwise lead to breakage again. And when you’re working on it, treat yourself to a small work surface or a protective mat so nothing gets scratched or lost.
You can do it! And if you have any questions – bring them on! :-)
