ᐅ BILLY shelf in the children's room – designed to be sturdy and safe.
Created on: 20 Aug 2024 09:37
ribagu
ribagu
20 Aug 2024 09:37
I am planning to use a BILLY shelf from IKEA for a child's room and want to make sure above all that the shelf is sturdy and safe for young children. It should withstand everyday use—even occasional rough handling like climbing or playing around it. Child safety is very important to me, including preventing the shelf from tipping over and avoiding sharp edges.
My question is: What is the best way to make the BILLY shelf robust and, most importantly, safe in a child's room? Are there proven methods for stabilizing it, adjustments during assembly, or special protective measures you would recommend? I am also interested in assembly aids, wall anchoring options, or protective covers. Additionally, I would like to know which versions of the shelf are better suited—such as the standard BILLY shelves or those with glass or wooden doors?
Looking forward to your detailed tips and experiences!
gasidney
20 Aug 2024 10:02
Always secure the shelf to the wall – IKEA provides the appropriate plugs and brackets for this.
For children, I recommend plastic or corner protectors for all edges.
Wooden fronts are more durable and child-friendly than glass.
If it should be climb-friendly, do not leave climbing aids or open gaps.
Palenar
21 Aug 2024 14:46
Hello ribagu,
First of all, kudos on your precise question – that’s already half the battle when it comes to getting targeted answers.
Regarding the stability and safety of the BILLY bookshelf in a child’s room, there are several important points you should consider:
1. Wall Fixing: BILLY bookshelves alone are not stable enough to prevent tipping, especially with active children. You should definitely use the included brackets and wall plugs – preferably with special expansion anchors depending on the wall type (e.g., concrete, drywall, or brick).
2. Reinforcement: For heavier loads, it can make sense to add extra bracing in the back panels. Some parents also attach a panel or thin board behind the shelf to increase stability and reduce play between the components.
3. Choice of Fronts: Wooden fronts are indeed preferable because glass can break in accidents, even though safety glass is usually used. If you still prefer glass, it should definitely be laminated safety glass (laminated glass). Alternatively, acrylic fronts are also an option; they are lighter and less prone to breaking.
4. Edge Protection: You are right, this is an essential point. You can attach edge protectors made of soft rubber or plastic directly to all relevant corners and edges. Make sure these fit securely and cannot be easily removed.
5. Mounting Height: Another aspect is the positioning of the bookshelf. Shelves mounted lower are easier for children to reach, which might encourage climbing. Therefore, it is advisable to place heavy and stable elements at the bottom and lighter ones at the top.
6. Accessories: For more stability, you can also use metal brackets for the shelves’ supports that can carry more weight. For open compartments where toys are stored, a non-slip surface on the shelf bottom can be helpful.
Personally, I would recommend the BILLY with solid fronts and wall fixing if the bookshelf is in a play-intensive child’s room. Would you like to tell me the size of the room and which walls are available for mounting? Then I can assist you more specifically.
Best regards!
warrenka57
22 Aug 2024 11:55
Hello ribagu,
I completely understand that you are especially concerned about safety when it comes to a children's room shelving unit. I also had a BILLY in our little one's room, and here’s what I learned:
Palenar schrieb:
BILLY shelves alone are not stable enough to prevent tipping, especially with active children.
I agree with that. At first, I didn’t realize how often children instinctively hang on or try to climb furniture. That’s why securing the unit to the wall was mandatory for us.
In addition, we covered all corners with soft plastic corner protectors. This significantly reduces the risk of injuries. They come in different widths and have a self-adhesive backing – in everyday use, they held up very well for me.
Make sure to check the fixings at least every two years to ensure they remain tight and secure, especially as the children grow older and use the shelf more intensively.
gasidney schrieb:
Wood fronts are sturdier and more child-friendly than glass.
I can only confirm that as well. The wood fronts also look more robust and are less prone to dents or cracks from impact.
I wish you the best of luck with your project – safety is the most important thing. 🙂
