ᐅ BILLY Shelving Assembly in Prefabricated Homes – Any Special Tips?
Created on: 27 May 2021 08:37
pofepraHello everyone,
I am currently planning to assemble an IKEA Billy bookcase in my prefab house. Since prefab houses often have specific wall constructions with less load-bearing materials compared to solid houses, I wanted to ask for tips or experiences that are specifically relevant to installing and securing Billy bookcases in prefab homes.
My main concerns:
- Which anchors or fastening materials are best suited for thinner drywall or wood paneling?
- Are there any tips on how to ensure the stability of the bookcase despite less load-bearing walls?
- Is it worth creating additional support structures or taking other measures?
I would be very grateful for any advice, especially from those who have already installed Billy bookcases in prefab houses!
Thank you in advance!
My main concerns:
there are a few important points to keep in mind when assembling BILLY shelves in prefabricated houses:
1. Wall mounting: As farGlen already mentioned, it is best to screw directly into the wooden studs. You can locate them using a small magnet or a stud finder.
2. If you only have drywall, be sure to use high-quality metal hollow wall anchors (toggle bolts). Plastic anchors often do not provide a lasting hold.
3. Use a spirit level and work precisely to ensure the shelf is horizontal and no stress occurs from uneven installation.
4. If the shelf will be heavily loaded, you can screw a separate wooden board from the inside to serve as additional support.
Summary: Focus on fixing into studs, using quality anchors, and, if necessary, adding a supporting substructure are key to success. Good luck with your assembly!
From my own experience, assembling furniture in a prefabricated house can sometimes be frustrating, especially when the walls are not as sturdy as in a solid masonry house. This often causes uncertainty about whether the shelf will actually hold.
That really helped me a lot! At first, I had concerns about the load-bearing capacity, but this way I could use it with complete confidence. Don’t hesitate to try these kinds of tricks; it’s definitely worth it. 🙂
naujon schrieb:
If the shelf is going to be heavily loaded, you can screw a separate wooden board from the inside to serve as additional support structure.
Thanks for the helpful tips so far!
A quick question: If I can’t easily find the wooden studs behind the drywall, how reliable are the drywall anchors you mentioned? Are they strong enough to hold a fully loaded BILLY shelf, or should I definitely try to hit the studs?
Also, how complex is it to install an additional wooden board behind the wall? Can I mount it myself, or do I need a lot of tools and experience?
Hey,
from my own experience, drywall anchors are a great solution, but if you have a lot of weight to support, they are only reliable up to a certain limit.
It’s not as complicated as it sounds. You just take a plywood or MDF panel cut to the right size and screw it directly to the studs behind the drywall. This gives you a much stronger base for the shelf. Tools needed: cordless drill, drill bits, and maybe a bit of patience. It really makes a big difference and makes the whole project much easier. 🙂
And don’t worry, spending a little extra time is always worth it!
pofepra schrieb:
How difficult is it to install an additional wooden panel behind the wall?
