ᐅ How to Assemble IKEA Malm Furniture More Stably – Tips?
Created on: 4 Jul 2019 19:17
Mikenau
Mikenau
4 Jul 2019 19:17
Hello everyone, I recently bought several IKEA Malm furniture pieces, including dressers and nightstands, but while assembling them, I noticed they often aren’t as stable as I expected. Especially when the drawers are fully loaded or the furniture is moved around, there can be quite a bit of wobbling. My question to you is: Are there any proven tricks or modifications to make the Malm series more stable? Maybe improvements that not only increase durability but are also reasonably affordable. I have considered using additional screws or wood glue, but I’m not sure where the main weak point is exactly. Perhaps you have experience or tips that really help? I would really appreciate any advice!
lejesin
4 Jul 2019 20:23
The issue with the somewhat limited stability of Malm furniture is well known, especially with drawer chests. A proven method is to reinforce the joints using additional wooden dowels and wood glue instead of relying solely on the standard screws and dowels.
Mikenau schrieb:
“Possibly improvements that not only increase durability but also remain reasonably affordable.”
Here, I would recommend first checking the fastening of the back panel: if it is not screwed in flush and tightly, the overall stability suffers significantly. Finally, installing corner braces under the furniture top greatly improves lateral stability. A few simple metal brackets from a hardware store can achieve a lot.
At the same time, replacing the thin back panel with a slightly thicker plywood sheet glued in makes the construction more stable while keeping costs low.
Gaupin68
4 Jul 2019 21:08
I have had good experiences when securing all connections additionally with threadlocker (Loctite). It also helps to tighten the screws properly, but without over-tightening. Once the back panel is in place, you have usually already made significant progress.
sarlo
5 Jul 2019 07:34
Regarding stability for IKEA Malm: It is especially important to work as evenly as possible. When assembling, first tighten all screws only lightly and only fully tighten them once all parts are properly aligned. This helps avoid stress in the components.
lejesin schrieb:
“Finally, angle brackets in the corners under the furniture top provide significantly better lateral stability.”
That is absolutely correct! For those who are unsure: These brackets come in various designs, can be installed fairly inconspicuously, and really add a lot of sturdiness.
I also recommend not only stapling the back panel but, if possible, securing it additionally with small nails or screws.
If time permits, you can even glue wooden reinforcements inside the corners – this will prevent wobbling in the long term.
putan
5 Jul 2019 10:42
A helpful tip that worked well for me: use Teflon or felt pads under the legs or feet of your furniture. This cushions movement and helps the dresser stand more firmly without slipping. It sounds simple, but it really reduces wobbling a lot! 😉
Also, if you use the drawers frequently, it’s worth considering metal drawer slides with ball bearings, if they’re not already installed. They slide more smoothly and put less strain on the furniture.
This small upgrade often makes a big difference.
eldubi
5 Jul 2019 12:21
As an alternative to tightening screws and installing brackets, you can additionally reinforce the joints of the side panels with small wooden strips. Simply cut them to size and secure them from the inside with screws. This increases stability without significantly changing the appearance of the furniture.
