ᐅ Are there specific assembly videos for Ikea PLATSA available on YouTube?
Created on: 7 Dec 2015 08:12
PebodraHello everyone, I am planning to get an Ikea Platsa system soon and have a fairly specific question: Are there any special assembly videos for Ikea PLATSA on YouTube that focus specifically on this system and explain the individual assembly and installation steps in detail? I already have the official Ikea instructions, but I am looking for visual support to avoid mistakes during assembly and to get a better overall understanding. It is important to me that the videos cover all relevant steps thoroughly and do not just include general furniture building tips. Does anyone have good knowledge about this or maybe even a specific channel or video that deals explicitly with the assembly of PLATSA?
Hello Pebodra, your question about specific assembly videos for Ikea PLATSA on YouTube makes a lot of sense, as assembling PLATSA is not exactly easy, and visual guidance helps a lot. When I assembled mine, I watched several videos tailored specifically to PLATSA. The advantage of these videos is that they often not only show the basic assembly but also provide practical tips on when and how to properly tighten the stability-critical screws or how to neatly connect the individual modules.
You should search specifically for videos that have "Ikea PLATSA assembly" or "construction" in the title or description. Often, private users share their own solutions and tricks. Large furniture influencers mostly cover standard kitchens or Kallax, while PLATSA is a bit more specialized but still represented.
A brief guide:
- Look for videos with high ratings and many comments, as these are usually the most reliable.
- Make sure the videos were uploaded in 2015 or later, since product details might have changed.
If you want, I can gladly select my favorites for you. Also important: some videos show more complex variants, so check beforehand if the model shown roughly matches your plan.
A brief guide:
I would like to elaborate on the answer a bit, as assembling the PLATSA system involves some tricks that are not immediately obvious. It’s true that there are specific assembly videos on YouTube, but their quality and level of detail vary greatly.
Here are a few tips to help you find the best video for your needs and how to proceed:
- First, you should define which PLATSA variant you want to assemble since the system is extremely modular and versatile. Videos that only show individual cabinets often don’t help much if you’re connecting multiple modules.
- Make sure the video doesn’t just show the assembly process superficially—many videos skip important steps like attaching the back panel or correctly positioning the dampers, which are crucial for stability later on.
- A particularly good tip: check if the video shows the correct assembly sequence. With PLATSA, it’s advisable to build the frame first and only then install shelves or doors that are lying around. Some videos ignore this, leading to avoidable issues.
- Usually, more specialized videos also include recommendations for tools and aids that can make assembly easier. Many forget, for example, that a cordless drill with the right bit can significantly speed up the work.
- Finally: if possible, compare several videos to see different approaches. This helps prevent misunderstandings and saves time.
If you like, I can provide a list of especially good and detailed videos and channels. For that, I would just need to know exactly which models or configurations you are planning, as there are significant differences.
TUELBA schrieb:
A particularly useful tip: Check if the video shows the correct assembly sequence. With PLATSA, it’s advisable to build the basic frame first and only then attach any loose shelves or doors.This is indeed a very important point. I have seen quite a few cases where exactly this mistake was made, leading to a lot of confusion in the end. Also, with PLATSA, it is crucial to use the connecting elements correctly, for example the metal connectors, which are often overlooked or installed incorrectly.
Sometimes it helps to download the official assembly instructions from Ikea first and watch the video simultaneously. This works very well together, especially if you prefer visual support.
One more tip: when choosing videos, pay attention to the comment sections. If many users provide feedback or ask questions and the creator responds, that's usually a good sign of a helpful and reliable video.
I find the whole search for special assembly videos often exaggerated. The Ikea instructions are more than sufficient, and for a simple shelving system, you can actually assemble it without a video.
Unless you are completely new to Ikea or have no experience with DIY at all, I think videos are often a waste of time. Videos rarely provide additional information; they usually just show the same as the instructions – but with less structure.
But sure, if someone feels that helps them, they should watch them. Personally, written instructions are perfectly enough for me.
Pebodra schrieb:
I already have the official Ikea instructions but am looking for visual support to avoid mistakes during assembly
