ᐅ Are there any special reinforcements available for IKEA Platsa?
Created on: 17 Jan 2023 08:27
TobotuHello everyone,
I am currently planning a new storage system based on IKEA Platsa and have a question about whether there are any special reinforcements or additional accessories specifically designed to stabilize Platsa components.
Specifically, I am interested in whether there are official or proven reinforcement methods that ensure higher load capacity, for example with larger shelving combinations or when storing heavy items.
Does anyone know of suitable solutions or have experience with making Platsa safer and more stable without having to switch to a completely different type of furniture?
I appreciate any constructive feedback and implementation tips. Thanks in advance!
Tobotu schrieb:
I am currently working on planning a new storage system based on IKEA Platsa and have the question if there are any special reinforcements or additional accessories specifically designed to stabilize Platsa units.Hi Tobotu, that’s a really good question! 😊
I’ve built Platsa units several times myself and can say that there are indeed accessories that significantly improve stability. For example, there are extra metal brackets that can be installed inside to prevent the modules from wobbling or warping under heavy loads. Also, backing panels made from sturdy particleboard help a lot.
In addition, I’ve sometimes reinforced the back panel with screws to make it even more stable. There isn’t an official reinforcement kit from IKEA specifically for Platsa, but with a bit of creativity, you can achieve great stability!
Don’t get discouraged—you’ll definitely be able to make it solid! 💪
Tobotu schrieb:
whether there are special reinforcements or additional accessories specifically designed to stabilize Platsa unitsHello Tobotu,
Since you are asking about special reinforcements for IKEA Platsa, I’d like to provide a more detailed explanation, as the topic involves some nuances. Platsa is designed so that individual modules can be easily combined and mainly rely on IKEA’s standard components (dowels, back panels, screws). However, official additional reinforcements from IKEA are not provided.
What is commonly used in practice:
- Reinforced back panels: The original thin particleboard back panels provide only limited stability. Many users opt for extra, thicker back panels that are cut to size separately and fixed with suitable angle brackets.
- Metal angle brackets inside: These are installed in the corners to prevent twisting. It is important to use the correct screws that do not go through the furniture piece.
- Floor level and wall attachment: Platsa modules, especially when stacked or combined, should always be secured to the wall. IKEA supplies special angle screws for this purpose.
- Heavy loads: If you intend to load the system heavily (with heavy equipment or many files), I recommend distributing the load evenly and adding multiple fixing points.
If you like, I can provide more technical details and recommendations if you explain your specific use cases. With such information, the appropriate reinforcement strategy can be defined more precisely.
kulau schrieb:
Platsa is structurally designed so that the individual modules can be easily combined and are mainly based on IKEA standard fittings (dowels, back panels, screws). However, official additional reinforcements from IKEA are not provided.I agree with this.
Some practical tips based on my experience:
- Always use the supplied wall mounts, especially for tall or wide Platsa combinations.
- If you plan to store heavier loads, use additional metal brackets in the corners. This significantly increases stability.
- Make sure to align the individual modules very precisely and in pairs to avoid later twisting.
- An alternative is to add internal reinforcements made of plywood or aluminum profiles. This requires professional skill and accurate cutting.
Basically, there are no official extra reinforcements for Platsa, but mechanical improvements are feasible and common.
bauku schrieb:
There is no official reinforcement kit from IKEA specifically for Platsa,Exactly, I would like to add that the stability of Platsa mainly depends on several factors.
- Material thickness of the individual components (panel thickness and coating)
- Proper assembly and precise alignment
- Quality control of the parts
For reinforcement, the following are suitable:
- Metal brackets mounted inside at exposed corners. Be sure that the screws do not damage the front surfaces.
- Additional back panels, as Kulau already mentioned, which can be custom-made from 6-8 mm (1/4–5/16 inch) plywood.
- Connections between stacked modules using appropriate screws to prevent shifting.
- Securing the units to the wall is mandatory and must not be neglected.
If you plan to use Platsa as a room divider or with exposed sides, I strongly recommend including structural stabilization, for example with extra support strips or legs.
Have you already designed a specific configuration? Then we can discuss the reinforcements in detail.
