ᐅ Are there any seasonal maintenance recommendations for Ikea HEMNES furniture?
Created on: 6 Nov 2023 08:37
sarjody
sarjody
6 Nov 2023 08:37
Are there any seasonal care recommendations for Ikea Hemnes furniture? I own several pieces from the HEMNES series, mainly made of solid pine, and I am wondering if I should take different measures depending on the season to best protect the wood and extend its lifespan. I am particularly interested in advice regarding humidity, temperature changes, and possible effects from heating air in winter or stronger sunlight exposure in summer. Are there any special seasonal care tips beyond regular cleaning, or should I simply treat and maintain the furniture consistently throughout the year?
FAVALERIE9
6 Nov 2023 09:02
For HEMNES, the general rule is to avoid keeping the wood too dry or too moist. In winter, reduce heating near the furniture and instead increase the humidity. In summer, protect the furniture from direct sunlight; this is usually sufficient.
klo61
6 Nov 2023 10:15
Hello sarjody, your question is very relevant. With solid pine wood like that used in HEMNES, humidity does play an important role. In winter, when the heating is on, indoor air often becomes very dry. This can cause small cracks in the wood or lead to some movement in the furniture. I recommend using a humidifier or at least ventilating regularly to keep the humidity stable at around 40-60%. In summer, it is less of an issue as long as you don’t place the furniture in direct sunlight, since UV rays can bleach and dry out the wood. For cleaning, depending on the level of dirt, you can use a slightly damp cloth and a mild wood care product that is not too aggressive. In general, it is important to monitor humidity seasonally and protect the furniture accordingly.
GALEO4
6 Nov 2023 11:19
I think this topic is often overcomplicated. Furniture is meant to be used—whether it’s HEMNES or other series. Why stress about seasonal care instructions? Just dust regularly, apply a bit of oil or wood conditioner occasionally, and that’s it. The wood won’t suddenly fall apart just because you don’t do extra maintenance in winter. In fact, this kind of overcautious attitude often leads people to constantly want to change things instead of just using their furniture. Of course, direct sunlight and extreme heat aren’t ideal, but that’s not some seasonal special rule—everyone basically knows that.
Mufato
6 Nov 2023 12:05
So, I would say the most important points are: avoid sudden temperature changes, and do not expose the wood to direct sunlight. Otherwise, regularly dust and gently clean with a suitable mild cleaner when necessary. That is completely sufficient for everyday care.
lyndon
7 Nov 2023 07:42
Interesting discussion. I would like to add: When you have dry air in winter, every wooden surface suffers. Similarly, too much humidity can promote mold growth. It is important that the indoor climate remains as balanced as possible, meaning that fluctuations in humidity and extreme temperature changes should be avoided. This applies to HEMNES furniture just as much as other wooden furniture. Additionally, it can be helpful to treat the furniture once a year with a maintenance oil or wax to protect the surface. You should use products that are suitable for pine wood. However, this should be more of an annual routine rather than something that varies seasonally.
