ᐅ Are there reinforced versions of BILLY shelves designed for heavier loads?
Created on: 26 Oct 2019 14:37
HOWARDSAUH
HOWARDSAU26 Oct 2019 14:37Hello everyone,
I am planning to use some IKEA Billy bookcases to create a more extensive book archive. This raises the question: Are there reinforced versions of the Billy bookcases from IKEA or other suppliers designed for higher loads? The standard Billy shelves are intended for regular books and lightweight items.
I am specifically looking for variants or modifications that allow for significantly higher load capacity so I can safely and long-term store heavier items – for example, large art books, technical manuals, or even small collections of binders.
Does anyone have experience with this or useful tips on whether there are official or unofficial reinforced Billy versions or how to make existing shelves more stable? I would greatly appreciate any advice, suggestions, or shared experiences.
reoleon4726 Oct 2019 15:09Hey HOWARDSAU, that’s a really interesting question! 😊
I’ve already reinforced my BILLY shelves with additional metal brackets, which significantly increased their load capacity. There are also special multiple shelf supports available that can be retrofitted.
Unfortunately, IKEA doesn’t offer an official reinforced version of the BILLY shelves, but with a bit of DIY work, you can upgrade them. There are also projects where people have installed metal pipes or thicker boards.
I think it’s a really cool challenge to customize the unit like that! Good luck with it! 🙂
HOWARDSAU schrieb:
Are there reinforced versions of the BILLY shelves from IKEA or other suppliers designed for higher loads?
Hi HOWARDSAU,
BILLY is basically the workhorse among shelves – but you definitely need to be careful with the weight. 😅
In my experience, the key is to anchor the shelves, for example to the wall, and also to add internal reinforcements.
That sounds great! One idea would also be to replace the shelves with stronger material or reinforce them with double layers.
Overall, with a bit of DIY skill, you can really get a lot out of it without having to build a custom shelf. 😉
reoleon47 schrieb:
stabilized with additional metal brackets, which really allowed me to increase the load capacity significantly.
I can understand that the standard BILLY model sometimes isn’t sufficient, especially when you want to store heavy and important items – that can really be a concern.
In your case, I would carefully consider which books or folders absolutely need to go on the shelf and which might be stored elsewhere if the unit is under too much strain.
And yes, I think the tip about reinforcing with metal brackets is a good one, but it’s also important not to overload the shelf, so you can have peace of mind. 🙂
HOWARDSAU schrieb:
...so that I can safely and reliably store heavier loads over the long term...
Good morning everyone! ☀️
I love BILLY, but I have always been a bit concerned about the weight capacity. If you really want to load it with many heavy books, you can even find reinforced wooden boards for the shelves online, made to fit BILLY perfectly.
That really worked wonders for me! The combination of sturdier shelves plus wall mounting = rock solid. Go ahead, turn your shelf into a powerhouse! 🙂
Nicksin schrieb:
Replace the shelves with stronger material or reinforce them double.
