ᐅ Are there any issues with IKEA Hemnes furniture in high humidity conditions?
Created on: 20 Mar 2023 08:17
Ripin
Ripin
20 Mar 2023 08:17
Hello everyone, I have a specific question I would like to clarify in this forum: Are there any known or common issues with the IKEA Hemnes furniture range, especially under high humidity conditions?
I am referring to situations where solid wood furniture like Hemnes is placed in rooms that are frequently exposed to moisture – for example, kitchens, bathrooms without permanent ventilation, or certain basements.
I am particularly interested in whether there are reports of typical warping, wood swelling, cracks, or damage that can be attributed to these climate conditions.
Additionally, I would appreciate any advice on how others deal with this issue – for example, through maintenance, additional protective measures, or choosing a suitable location.
Thank you in advance for your insights and experiences!
juMira46
20 Mar 2023 08:45
Ripin schrieb:
Are there any known and/or common issues with the IKEA Hemnes furniture range, especially under high humidity conditions?
Hey Ripin, wood can definitely cause some typical problems in high humidity—like swelling, small cracks, or the usual “sweating.”
Although Hemnes is solid wood and quite sturdy, it does prefer dry air. In kitchens or bathrooms, you might notice doors warping slightly or the finish losing its shine.
A quick tip: regular maintenance (e.g., wood oil or special sealants) and ventilation can help prevent these issues.
So, yes, I’d say there are typical problems, but they’re usually avoidable if you take the environment into account. 😉
SauDietmar
20 Mar 2023 09:03
To better understand the situation with IKEA Hemnes furniture in highly humid rooms, here is an overview of the key points:
- Hemnes is mostly made of solid pine wood. This type of wood is sensitive to fluctuations in moisture.
- High humidity causes the wood to absorb water, which can lead to swelling.
- Especially when humidity levels remain above 60-70% for extended periods, the wood fibers can expand, causing warping or deformation.
I recommend the following measures:
- Allow the furniture to acclimate in a dry room before installation whenever possible.
- Use dehumidifiers or ensure consistent ventilation.
- Avoid direct exposure of the furniture to water.
- Regularly maintain the surface with appropriate oils or varnishes.
In summary: Problems can occur and are often due to excessively high and prolonged humidity.
noge58
20 Mar 2023 10:21
I had the Hemnes bed in my bathroom for two years – seriously! 😄 Of course, it’s not the ideal environment, but with a few tricks, everything held up really well.
- Always well ventilated, even if it’s sometimes a hassle
- Applying wood preservative oil at least once a year
Of course, there was some maintenance needed for the wood, but I didn’t notice any warping or cracks – so no need to worry!
I think with some effort it’s definitely doable, as long as you’re not living in a sauna. Take this as motivation!
Ripin
20 Mar 2023 11:02
SauDietmar schrieb:
Especially when humidity levels remain above 60-70% for extended periods, wood fibers can swell, leading to warping or deformation.
What would you recommend as a permanently acceptable humidity range to minimize the risk for Hemnes furniture? Would it be around 45-55%?
Are there any practical experiences regarding whether Hemnes wood is more sensitive than, for example, MDF furniture? I am mainly concerned about a constant condition, not occasional spikes in humidity.
Thanks in advance!
PULAU
20 Mar 2023 11:40
Addressing your questions, Ripin:
Solid pine, like in Hemnes furniture, generally reacts more strongly to moisture than MDF or particleboard because the wood is hygroscopic and absorbs or releases moisture, causing changes in volume.
A relative humidity range of 40-60% is optimal to minimize warping. Persistent levels above 60% significantly increase the risk of swelling.
It is also crucial to keep temperature and humidity as stable as possible to prevent the wood from constantly expanding and contracting.
My advice: Maintaining around 50% humidity and regular ventilation is the safest approach.
