ᐅ Are there any common issues with IKEA Hemnes furniture, and how can they be resolved?
Created on: 24 Nov 2022 18:27
Gauan
Gauan
24 Nov 2022 18:27
In recent weeks, I have heard from several users that there are certain defects or weaknesses with IKEA Hemnes furniture, especially with dressers and beds, which only become apparent over time. I am particularly interested in knowing if there are any known, systematic issues—such as with the material quality, hinges, or stability—and how to best fix or prevent them.
Has anyone had experience with Hemnes shelves or Hemnes beds where screws have come loose, the wood has given way, or drawers no longer slide properly? Are there any clever DIY solutions or official repair guidelines you would recommend?
I would appreciate a detailed assessment, preferably with advice on how to restore functionality without having to replace everything.
SauDietmar
24 Nov 2022 19:46
Hello Gauan,
I’m happy to use this thread to summarize some of the most common issues with IKEA Hemnes furniture and provide tips on how to address them.
- Material issues: Hemnes is usually made of pine wood or MDF with real wood veneer. Pine in particular is sensitive to moisture, which can cause swelling or small cracks. Recommendation: Keep humidity levels low and protect the wood surface with furniture wax or a special wood oil.
- Hinges & fittings: Screws often loosen over time. My advice is to regularly tighten connections using the appropriate Allen wrench or screwdriver. If the threads wear out, inserting a wood shaving with a toothpick or using wooden dowels can help.
- Drawers & slides: For problems with sticking drawers, it’s advisable to clean the slides and lubricate them lightly (e.g., with silicone spray). Sometimes it’s worth replacing the slides if they are bent.
- Stability: Some Hemnes beds are notorious for squeaking and unstable footing. I have had very good results adding angle brackets or metal connectors at joints to significantly improve stability.
If you have specific questions about a particular piece of furniture, I’m happy to provide more detailed answers.
theota
24 Nov 2022 20:03
SauDietmar schrieb:
If you have issues with sticking drawers, it’s recommended to clean the tracks and apply a light lubricant (for example, silicone spray).
I think there is too much focus on minor repairs. The Hemnes series is often marketed as “solid wood,” but many underestimate that the quality deteriorates quickly, especially after repeated assembly and disassembly. I argue that anyone looking for truly durable furniture should avoid Hemnes as a long-term solution. Repairs usually work, but to me they feel more like patchwork.
nonlau35
24 Nov 2022 20:47
The most common issues are loose screws and squeaky beds. Tightening the screws and applying a bit of lubricant to the joints usually resolves the problem quickly.
Takutau
25 Nov 2022 08:14
I would like to add some information for those who are new to Hemnes:
Assembly is crucial for durability. Hemnes furniture is solidly built, but the wood has natural variations. Make sure to initially tighten all screws only by hand, then systematically fully tighten them afterwards to avoid uneven pressure or warping.
If a hinge stops working, the cause is often found: incorrect screw placement or worn metal parts. Replacing hinges can be done by yourself with some patience.
Also important: Hemnes furniture made of pine should not be left in damp environments for weeks, as this can cause long-term issues.
For drawers, it is recommended to periodically check their alignment; often a small adjustment can resolve sticking problems.
V
vin_leo
25 Nov 2022 09:33
I think the Hemnes series isn’t that bad if you know what you’re doing. My drawers have occasionally been a bit troublesome, but with some lubricant and rough adjustment, everything runs smoothly again.
A tip for those who have annoying squeaking noises with beds: a little wax or felt pads at the contact points between the wood can work wonders. This way, you can keep the comfort in bed without constantly having to deal with irritating noises.
