ᐅ Are there insulating underlays for Kallax on cold floors?
Created on: 18 Jan 2019 10:12
Tidima
Tidima
18 Jan 2019 10:12
Are there insulating pads for the Kallax shelving system from IKEA that are specifically designed for use on cold floors? I plan to place my Kallax directly on an unheated basement floor, where moisture and cold could be an issue, especially in winter. My questions are: Are there pads that provide insulation against cold while also repelling or managing moisture? It would also be ideal if they are durable and strong enough to support heavy loads, as I intend to fill the shelf with heavy items. Does anyone have experience or recommendations for suitable materials or specific products?
landen
18 Jan 2019 10:45
Hey, I read your concern and think it’s really important! 🙂 Cold floors can actually be quite damaging to furniture, especially when it comes to moisture. There are insulating underlays available, but most of them are actually designed more for technical uses, like building materials or insulation mats.
Personally, I’ve had good experiences with self-adhesive PE foam boards—they insulate well and are relatively inexpensive. They also provide some cushioning if the floor isn’t completely even. It’s important that the underlay is definitely moisture-resistant, otherwise the wood in the shelving unit might warp over time.
But honestly, Kallax isn’t exactly a lightweight shelf, so you really need to make sure the insulation can handle the load. Maybe use multiple layers or a firm rubber mat underneath? 😉
Tommy38
18 Jan 2019 11:23
A good point raised by landen!
To add: insulating underlays for furniture purposes need to fulfill several requirements: thermal insulation, moisture protection, and load-bearing capacity. Special insulation boards for floors, such as extruded polystyrene foam (XPS), are particularly suitable because they have low thermal conductivity and also absorb very little moisture.
You can also check out hardware or craft stores, which often sell boards in various thicknesses to address such issues. For furniture like Kallax, however, I would recommend cutting the underlay so that not only the floor but also the bottom edge of the shelving unit is protected.
In general: even a few millimeters can make a big difference here.
batabe
18 Jan 2019 12:02
I would like to add that you should also make sure that the underlay does not slip, especially on smooth concrete floors in the basement. Some of the insulation mats are very smooth and may shift under load.
A non-slip rubber or felt coating on the underside can make a big difference here. Alternatively, you can also use additional anti-slip pads.
It is also really advisable to keep the shelving slightly raised off the floor to prevent any contact with moisture—for example, by placing small wooden blocks under the feet.
flota
19 Jan 2019 08:17
I agree with the previous posts but would like to focus especially on durability and the physical properties.
For a long-lasting solution in cold, potentially damp environments, materials such as polypropylene insulation felts or cork panels are worth considering. Cork has the advantage of being natural, vapor-permeable, and still insulating.
Technically, cork’s thermal conductivity is significantly lower than that of wood, which results in noticeably better insulation. At the same time, cork does not absorb moisture, protecting the shelf board from mold.
By cutting it to fit the specific Kallax frame dimensions, you can create an effective insulating layer that can also withstand the load of a fully stocked shelf.
lukin
19 Jan 2019 09:56
flota schrieb:
Cork has the advantage of being natural, vapor-permeable, and yet insulating.
This is often overlooked, even though it is very important. If something is completely airtight and not vapor-permeable, moisture can become trapped and cause problems.
In my basement, I have cork boards under my shelves, with a thin rubber mat on top to protect against water damage. This works very well and prevents cold air from the floor from directly affecting the shelves.
It is important to make sure the boards are not too thin – at least 10 mm (0.4 inches), preferably a bit thicker – otherwise their effectiveness is too low.
