ᐅ Are there any Ikea Pax options with an integrated pull-down wardrobe rail?
Created on: 23 Sep 2024 14:07
matspeo
matspeo
23 Sep 2024 14:07
Hello everyone, I am currently considering purchasing an Ikea PAX wardrobe but am still unsure about the practical features. My specific question is: Are there any current PAX wardrobe models from Ikea that come factory-equipped with an integrated pull-down rail? I am thinking of a kind of extendable lift system that makes accessing higher clothes easier and therefore makes using the upper compartments much more convenient. If such models are not directly offered by Ikea, I would also be interested in possible alternative solutions or recommendations that are compatible with the PAX system. Thanks in advance for your expertise.
Fitigu
23 Sep 2024 14:43
Hello matspeo, regarding your question: Ikea currently does not offer a PAX wardrobe with an integrated pull-down closet lift directly from the factory. The PAX system is modular and provides various interior fittings such as drawers, shelves, clothes rails, and swing-out trays, but it does not include a lift mechanism.
Alternatively, there are several accessories and third-party products available that offer lift attachments or extendable closet lifts, which can be installed later in PAX wardrobes. When considering these, pay attention to:
- Dimensions and structural strength of the components
- Load capacity of the lift mechanism
- Compatibility with the PAX wardrobe sides
Another option is using so-called “pull-down” clothes rails, which Ikea occasionally offers as an organizational aid, though not specifically for the PAX range.
Domau0
23 Sep 2024 15:28
Fitigu schrieb:
Ikea currently does not offer a PAX wardrobe with an integrated pull-down closet rod as standard.
That is correct, but there are a few details to consider when retrofitting one. A typical PAX wardrobe has side panels pre-drilled with slotted holes, which are very suitable for various hanging fixtures. If you want to retrofit a pull-down closet rod, the following points are crucial:
- The fittings must be compatible with the hole spacing.
- Operability: The lever should be easy to pull forward, ideally with dampers.
- Space requirements: Since PAX is available in different depths (35 cm or 58 cm) (14 inches or 23 inches), the lift should be matched to the depth.
I purchased a pull-down closet rod from a third party for a similar project, specifically designed for IKEA PAX. After installation, the handling is very convenient, as it makes shirts or jackets stored high up easily accessible. If you are interested, I can provide you with the technical data and installation instructions.
matspeo
23 Sep 2024 16:02
Domau0 schrieb:
I bought a clothes lift from a third-party supplier for a similar project, which was specially adapted for IKEA PAX.
That sounds very interesting, thanks for the information! I would appreciate it if you could send me the technical specifications and installation instructions. What matters most to me is compatibility with the standard width of 100 cm (39 inches) and a cabinet depth of 58 cm (23 inches). Are there any technical challenges during installation, or can it be done easily with some basic DIY skills?
I’m also open to alternative operating concepts if it means the lift can be integrated more easily. By the way, what about the load capacity? This is important to me since I plan to hang thicker jackets and shirts.
koduga
24 Sep 2024 08:16
I think it’s great that practical solutions like these are being discussed here! From my own experience, a clothes lift in a tall wardrobe really makes everyday life easier. At first, I also had concerns about the effort involved in installation and the stability, but with the right instructions and a bit of patience, it works really well.
Regarding matspeo: Don’t get discouraged. There are many videos and guides that help most people succeed easily. Just make sure that no overly heavy garments are placed on the lift, as this can cause wear or damage too quickly.
Smaller jackets and shirts are no problem, as the lifting systems are designed for that. I also like that it allows you to use storage space more efficiently.
Davidleo
24 Sep 2024 10:39
Hey everyone! It’s really exciting that this topic is coming up here! I personally love my PAX wardrobe with a pull-down clothes rail that I installed from a third-party supplier. It’s truly brilliant because you can easily reach everything at the top without having to get a ladder or anything! 😊
koduga schrieb:
Don’t get discouraged, there are plenty of videos and guides that most people manage really well.
Absolutely, the installation videos helped me a lot. And the lift is still working perfectly after months – much more convenience for relatively little effort! I can only recommend it if you want to make the most of the height.
