ᐅ Are there DIY repair kits available for minor damage to BILLY furniture?
Created on: 30 May 2020 08:17
eskilnar
I have a question that has been on my mind for some time, especially since I’ve noticed some minor damage on my Billy shelves, which of course you don’t want to replace or exchange forcefully.
So: Are there any proven and practical DIY patches or repair solutions for small scratches, dents, or chipped areas on BILLY furniture (especially the white or oak-veneered versions)? I mean specifically homemade methods or hacks that can be done using simple materials from a hardware store or household supplies to restore the overall appearance without having to order expensive replacement parts.
Perhaps you have experience with these kinds of self-repairs or know tips for making minor wear and tear invisible, including advice on the different surfaces or materials of BILLY furniture.
Thanks in advance!
chen67
31 May 2020 10:03
Hey, classic questions here! I always like seeing how carefully you approach things 🙂
So, about sanding: Yes, be careful with melamine! It can get damaged very quickly. For my BILLY, I usually just lightly roughened one edge to help wood filler adhere better.
A little tip from me regarding paint: Sometimes it helps to thin acrylic-based paint slightly with a bit of water, so it applies thinner and more evenly.
And psst: I often spray on a very thin layer of clear varnish afterward. It makes the surface less prone to new scratches 🙂
laume
1 Jun 2020 07:41
Hello eskilnar,
to address your concerns about sanding melamine: yes, the coating is delicate. Sanding should be done very carefully and only with very fine sandpaper. The goal is just to slightly roughen the repair area to improve the adhesion of filler or paint.
Otherwise, the following applies:
- For scratches, a wax stick or furniture touch-up pen often helps.
- For small holes or gaps, wood filler can be used, sanding only minimally afterward.
- Always seal the repair after it has dried to keep moisture out and make the surface more durable.
Good luck, you can do it!
