ᐅ Are there different types of wood used in Ikea Platsa?
Created on: 16 Oct 2020 09:13
Jugilen
Jugilen
16 Oct 2020 09:13
I have recently started to look more closely into Ikea’s Platsa systems, mainly because I’m searching for flexible and functional closet solutions for several rooms. I noticed that Ikea often uses various types of wood or wood-based materials for other furniture pieces: solid wood, veneered particleboard, or MDF in different qualities.
Now I specifically wonder if this is the case with Platsa as well, or if only one particular material is used throughout. I mainly need this information to better assess durability, appearance, and weight, as well as whether this affects maintenance or handling.
Has anyone gained more detailed insights or experience regarding the types of wood or wood-based materials Ikea uses in the Platsa system? Are there differences between the various components (e.g., carcasses, fronts, or shelves)?
Any information on surface treatment or sustainability would also be appreciated if anyone has knowledge about that.
kogudra
16 Oct 2020 10:29
Ikea Platsa primarily uses medium-density fiberboard (MDF) and particleboard, coated with melamine resin, especially for the carcasses.
The fronts of Platsa can vary depending on the model but are also usually made from MDF or particleboard with foil or paint finishes.
Solid wood is not used in Platsa in order to keep costs and weight low.
The different components are therefore consistently made from the same material groups. This ensures interchangeability and easy assembly.
Important: Platsa is not a piece of solid wood furniture, which should be kept in mind regarding durability and repairability.
Tobias
16 Oct 2020 11:05
Platsa is basically made from particleboard and MDF. There are no different types of wood. The surface is either melamine-coated or painted.
Edric
16 Oct 2020 12:43
I think it’s important to keep in mind that, especially for furniture like Platsa, which is meant to be flexible, using different types of wood could actually be more of a drawback.
I personally had some issues with moisture at the edges because the coating isn’t completely waterproof. This is probably due to the material used, which is not solid wood.
kogudra schrieb:
Solid wood is not used in Platsa to keep costs and weight down.
To be honest, I hadn’t fully realized that when I made my purchase. Thanks for clarifying.
Donar34
16 Oct 2020 14:18
For clarification:
- Ikea Platsa does not use different types of solid wood in the traditional sense, but exclusively industrially manufactured wood-based panels.
- The dominant materials are MDF and particleboard with melamine-coated surfaces.
- The fronts vary, with options featuring either laminated or painted finishes, which differ slightly in texture but not in the wood-based material itself.
- According to my research, no solid wood components are used.
- This is important for durability, as MDF and particleboard are generally more sensitive to moisture.
Conclusion: Traditional wood species are not to be expected in Platsa; rather, it consists of standardized wood-based panels with various surface treatments.
giabau
17 Oct 2020 07:48
A brief summary with some details that are important for practical use with Platsa:
- Cabinets: MDF or particleboard, mostly melamine-coated.
- Fronts: Also MDF or particleboard, covered with foil or lacquer. Some models may vary, but always engineered wood products, never solid wood.
- Shelves: Also mostly particleboard, with edge banding or melamine foil.
Common assembly mistakes include over-tightening screws due to the relatively soft MDF edges. It is recommended to use the supplied torque settings and screws.
For care: Clean only with a damp cloth, avoid harsh cleaners as they can damage the foil or melamine surface.
In summary, there are no different wood types in the Platsa system, but mainly MDF and particleboard in various finishes.
