ᐅ Are there differences in the drawer slides used in Ikea Pax wardrobes?
Created on: 16 Feb 2024 09:27
rureo51
rureo51
16 Feb 2024 09:27
I am currently looking into drawer slides for the Ikea PAX system and have come across a question that I would like to ask clearly here: Are there actually differences between the drawer slides Ikea offers for the PAX system?
I am not only referring to visual differences but also technical aspects such as load capacity, smoothness of operation, installation details, and possibly different types of extension (e.g., full extension or partial extension).
I am particularly interested in whether you need to choose specifically based on requirements like stability or ease of installation, or if Ikea offers more of a uniform product line.
Can you help me with your experience or detailed knowledge of the product range? Thanks!
KINMIN4
16 Feb 2024 10:03
Basically, Ikea offers two main types of drawer slides for PAX: full extension with soft-close and standard extension without soft-close. The load capacity is usually around 15 kg (33 lbs) per drawer. The differences in the runners are mainly noticeable in the soft-close system. Technically, they are not the same, so it is important to pay attention to the type of extension.
Palenar
16 Feb 2024 11:47
Very interesting question that deserves more attention. In fact, there are clearly distinct variants of the Ikea PAX drawer slides, which differ both technically and functionally.
- Ikea primarily uses two main types: ball-bearing slides with and without soft-close. The soft-close version includes integrated dampers that mechanically cushion the drawer’s closing movement.
- The load capacity varies depending on the type of slide, with standard slides usually supporting around 20 kg (44 lbs), while soft-close models often have slightly less dynamic load capacity but are more stabilized.
- In terms of installation, it should be noted that soft-close models are somewhat more complex to install, as they require more components and more precise adjustment.
Question: What exact drawer size are you planning, and what load capacity do you expect? In my experience, this significantly influences the ideal choice.
SONLIS
16 Feb 2024 13:12
In my opinion, it is important to distinguish the intended use of the drawer slides in the PAX system.
The soft-close rails provide smoother operation and help preserve the furniture over time. However, for heavy loads, it is also important to consider the load capacity, as not all IKEA slides are equally robust.
If the focus is on everyday practicality and comfort, soft-close slides are definitely recommended. From a technical perspective, there are no major surprises, apart from the integrated mechanical damper.
rureo51
17 Feb 2024 08:41
Palenar schrieb:
Question: What exact drawer size are you planning, and what load capacity do you expect? In my experience, this significantly affects the ideal choice.
That is a very valid question. I plan to use drawers 50cm (20 inches) wide and 40cm (16 inches) deep in a PAX frame. The drawers will mainly be used for clothing, so approximately medium load.
Are there any preferences or recommendations for these dimensions and usage regarding the type of drawer slides? Should I opt for full-extension slides, or would partial-extension slides be sufficient?
Looking forward to your insights.
RENMA
17 Feb 2024 10:19
The dimensions you mentioned fall within a very common range for PAX drawers. For clothing, full-extension drawers with soft-close mechanisms are usually sufficient.
- Full-extension slides allow the drawer to be pulled out completely, making the entire drawer depth usable.
- Partial-extension slides are generally intended for lighter loads or smaller drawers and limit accessibility somewhat.
The load capacity of standard PAX drawer slides for clothing should be adequate. When purchasing, pay close attention to the detailed product description, especially load limits and installation instructions.
