ᐅ Are there child-friendly options to make IKEA BESTA doors lockable?
Created on: 4 Oct 2015 08:23
gamal69
Hello everyone, I have a specific question about the IKEA Besta system, specifically regarding the doors: Are there child-friendly options to make the doors lockable? My main concern is to prevent small children from accessing the cabinet contents. Since the Besta doors do not come with locks by default, I am considering the best way to approach this without completely compromising the aesthetics or choosing bulky solutions. It is important to me that the solution is truly childproof, but also practical for everyday use and as discreet as possible. Does anyone have experience with suitable locks or other mechanisms that can be used with Besta doors? Thanks for your tips!
dopite
5 Oct 2015 13:14
I would like to offer a structured recommendation for anyone looking for a child-friendly way to make IKEA Besta doors lockable:
1. First, clarify your requirements: Do you really need a lock that can be fully secured? Or would a simple child safety lock that is difficult for children to open suffice?
2. If a fully lockable solution is needed, I would recommend:
- Magnetic locks, as mentioned several times, which are mounted on the inside and opened with a magnetic key.
- Installation requires some DIY skills, as the doors may need to be modified.
3. For a damage-free installation:
- Use adhesive child safety locks that are easy to remove.
- Or choose clamp locks that do not require drilling.
4. Alternative:
- A lockable handle, if compatible – but solutions here are rarer and often expensive.
Summary: If you want a permanent locking solution, you usually have to compromise on effort and possibly the furniture’s condition. Child safety locks are a middle ground, slowing down small children without fully locking everything. It is also important that the lock or safety device remains easy and secure for adults to operate.
If you like, I can recommend detailed installation guides!
NUGRANT
6 Oct 2015 11:47
I’m currently in the situation where I needed to childproof my BESTA cabinets. For me, it was important to find a solution that is enjoyable and doesn’t cause much hassle. That’s when I came across magnetic child safety locks – such a small, unobtrusive technology really makes a difference!
I also think that when you use the right solutions, they are perfectly practical for everyday use. Just keep the magnetic key somewhere handy, and that’s it.
There are also electronic locks, but in my opinion, they are overkill for IKEA cabinet doors and simply too expensive and complicated for most people.
Conclusion: My recommendation is definitely magnetic locks – child-friendly, visually unobtrusive, and effective!
alvalo
7 Oct 2015 07:35
gamal69 schrieb:
Since BESTA doors do not come with locks by default, I am considering the best way to handle this without completely ruining the aesthetics or choosing awkward solutions.
In my opinion, that is the core of the challenge!
A lockable solution either requires significant modification or usually results in visible changes to the design. This is especially problematic with existing furniture. Most childproof locks are designed to prevent access rather than to lock in the sense of a keyed lock.
Perhaps you could try securing the doors with magnetic catches on the inside—this leaves the outside untouched and effectively prevents children from opening them.
You should also test whether your children can quickly figure out how to open them—there are different experiences reported on this.
gamal69
7 Oct 2015 19:26
dopite schrieb:
I would like to give a structured recommendation for anyone looking for a child-friendly way to make IKEA BESTA doors lockable:
Thanks, dopite, that’s very helpful! Especially your points 1 and 3 show me that I need to clearly define my requirements again. I was initially thinking more of a lock with a key, but your explanations make me doubt whether that’s really practical for everyday use.
alvalo schrieb:
Most childproof locks are designed to prevent access rather than locking with a key in the traditional sense.
That’s a good point. Ultimately, the goal is to keep small children out, not to lock everything completely at all times. An easy-to-operate latch that adults can quickly open is often enough.
I will look more closely into magnetic locks and adhesive child safety locks. Thanks to everyone for your very helpful tips and different perspectives!
