ᐅ Are there child-friendly modification guides for Ikea Besta units?
Created on: 30 Mar 2022 08:37
gla54
gla54
30 Mar 2022 08:37
I am currently considering modifying my Ikea Besta shelving unit to make it more child-friendly. Specifically, I am looking for modification guides or instructions that focus on making the Besta system safe and practical for children. Important aspects for me include rounded edges, childproof locks, and possibly flexible usage options that can easily adapt to changing needs.
Has anyone had experience with this or knows of detailed plans or tutorials suitable for this purpose? It doesn’t necessarily have to be an official guide; well-documented DIY ideas would also be great.
Thanks in advance for any tips and suggestions!
flo-Theres
30 Mar 2022 10:24
Hello gla54,
Your question about child-friendly modification instructions for the Ikea Besta is very well considered. Basically, there are no official Ikea instructions specifically optimized for child safety, but there are some proven approaches you can take into account:
- You can further secure rounded edges with edge protection profiles made of soft plastic or silicone.
- Magnetic child safety locks are especially suitable because they are installed on the inside and therefore do not affect the appearance.
- Additionally, you should definitely anchor the shelving unit to the wall to prevent tipping hazards.
- For flexible use, removable shelf inserts or small boxes can be integrated, which are very easy for children to handle.
Even though there is no step-by-step guide from the manufacturer, I would recommend including these elements in your planning. If you like, I can suggest some sources where users have documented such modifications.
NoValentin
30 Mar 2022 12:11
flo-Theres schrieb:
You can secure rounded edges additionally with edge protection profiles made of soft plastic or silicone.
This is the most important tip.
Additionally: incorporate child safety devices such as simple latches or magnetic locks.
And: always anchor the shelf securely to the wall to minimize the risk of accidents.
Kinbu
31 Mar 2022 07:46
Good morning everyone,
I would like to add to the discussion since child-friendly modifications with Ikea Besta are frequently asked about.
It is important to note that the Besta modules are generally assembled using a simple plug-in system and screws, which makes modifications easier. For child safety, the following adjustments are particularly helpful:
- To protect edges, you can either buy ready-made edge protectors or use soft cushioning tape yourself. Ikea’s edges are often quite sharp, so this should not be underestimated.
- Magnetic locks work well for doors and drawers if you want to prevent small children from gaining access on their own.
- For older children, it makes sense to arrange shelves so they can reach everything themselves, for example by using lower shelves or removable boxes, which also help encourage tidiness.
- Securing the furniture to the wall is strongly recommended and often underestimated.
- Last but not least: Ikea now offers a child-safe version of their furniture through accessories like edge protectors and furniture locks, which can be used as additional safety measures.
If you are looking for specific building instructions, the best approach is usually through DIY blogs and forums like this one, where many custom solutions are presented. It’s worth searching for terms like “Besta child-friendly modification” or similar.
One more important note: safety aspects must never be compromised, especially with children’s furniture!
LOJOPAR
1 Apr 2022 18:53
to answer the question about child-friendly modification guides for the Ikea Besta in a more organized way, here is a brief overview of my experience in several steps:
1. Analysis of the existing shelving unit: Check which edges and corners could be potentially dangerous. To ensure safety, these should be softened with edge protectors or similar solutions.
2. Childproofing doors and drawers: Magnetic locks, as already mentioned, are very practical. The lock is installed invisibly inside, which is both visually appealing and effective.
3. Reinforcement and anchoring: Since children often climb on furniture or lean against it, secure anchoring to the wall is essential. Additional reinforcements can help make the shelving unit more stable.
4. Flexible compartment arrangements: There are special shelves and boxes that can be easily removed so that children can access their contents without having to empty or damage everything.
5. Individual customization: Depending on the child’s age, you can, for example, replace safety glass with plexiglass or install soft-close hinges to prevent finger injuries.
Common mistakes include:
- Not securing the shelving unit sufficiently
- Using insecure locks that children can easily open
- Remodeling later instead of planning child-friendly from the start
I hope these tips are helpful. If you like, I can also provide an example guide in a follow-up post.
