ᐅ Are there any maintenance recommendations for Ikea Hemnes furniture during the winter?
Created on: 15 Dec 2022 08:37
Z
Zarke
Z
Zarke
15 Dec 2022 08:37
I am currently wondering if there are any special care instructions for Ikea Hemnes furniture during winter, as my apartment tends to be heated more dryly in the cold season, and temperature and humidity fluctuations are noticeably stronger than in summer.
Since Hemnes furniture is mainly made of solid wood, I am interested in whether specific care measures or precautions are strongly recommended to reliably protect the wood from winter conditions. In particular, I would like to know if using care oils, special cleaning products, or humidifiers is advisable, and if there are any recommendations from Ikea or from your experience regarding optimal winter care.
I would be very grateful for any advice or experiences, as I want to avoid cracks or warping in the Hemnes furniture.
Friedrich
15 Dec 2022 12:48
Zarke schrieb:
whether there are any special care instructions for Ikea Hemnes furniture during winter
This is indeed an important question, especially since solid wood is quite sensitive to dry and cold air. I have Hemnes furniture at home myself and can confirm that I pay close attention to maintaining consistent humidity levels during winter – for me, this means using humidifiers and regularly ventilating the rooms to avoid both moisture buildup and overly dry air.
Zarke schrieb:
whether care oils, special cleaning agents, or humidifiers should be used
Exactly, that not only benefits the wood but also helps prevent cracks. In my experience, occasionally rubbing the furniture with a care product designed for wood furniture works well, but it should be done sparingly – ideally with products suitable for oiled wood. It’s nothing too elaborate, but it gives a good feeling of thorough maintenance.
If anyone here has additional experience with specific care products, that would definitely be helpful for everyone.
lubla
15 Dec 2022 14:22
For Ikea Hemnes in winter: pay attention to wood moisture and indoor climate. Ideal humidity is 40-60%. Use a humidifier if the heating air is dry. Applying maintenance oil twice a year is sufficient. Do not use aggressive cleaning agents.
JEREMIAH38
16 Dec 2022 19:05
Friedrich schrieb:
I have Hemnes furniture at home myself and can confirm that I pay close attention to maintaining consistent humidity levels during the winter
I completely understand that. Recently, I even noticed a small crack on one of the cabinet doors – as soon as I saw it, I started using a humidifier more regularly and began applying oil to the wood frequently.
What I can additionally recommend: place a small hygrometer in the room to monitor the humidity precisely. This is especially helpful in older buildings with significant temperature fluctuations.
Zarke schrieb:
whether there are specific care instructions for Ikea Hemnes furniture in winter
I haven’t found any specific statement directly from Ikea on this – but the Hemnes series is known for its durable construction. The best advice, as mentioned, is to maintain optimal indoor climate conditions and care for the wood with maintenance oil. Another tip is to avoid placing heat sources directly next to the furniture, as excessive heat can dry out the wood.
I hope my experience helps you!
