ᐅ Are there any cabinet handles that particularly suit IKEA Platsa units?
Created on: 8 Jan 2020 09:37
REOLAU33
REOLAU33
8 Jan 2020 09:37
I’m interested in furniture handles that work especially well with IKEA Platsa systems – both visually and functionally. The Platsa range is known for its flexible, modern, and minimalist design, but I find the original handles somewhat limited in terms of variety and impact.
My question is: Are there furniture handles you would recommend based on material, shape, or color that enhance the look of the Platsa cabinets while also improving usability? It would also be helpful to know what mounting types to consider, since the Platsa fronts are thin and not all handle types are compatible.
If you have personal experience with handles that are easy to install and hold up well, please share your tips! I’m really looking forward to your recommendations and reasoning.
Thank you!
O
onMarcos
8 Jan 2020 10:22
Hello REOLAU33,
your question about suitable handles for IKEA Platsa is very well asked, and there are indeed a few important points to consider.
First, the material and shape are important because Platsa often has painted or foil-covered surfaces, which can cause issues with handles that are too large or heavy. I generally recommend:
- Handles made of metal with a simple, clean design (e.g., bar handles or rounded knobs) that match the minimalist look of Platsa.
- Alternatively, handles made of matte aluminum or brushed steel that are not too shiny, to maintain the Scandinavian/minimal style.
Second, the mounting: Platsa fronts are usually thin, so it is essential to check the drill depth and screw length. IKEA often uses thinner panels, and screws that are too long can go through.
In summary:
- Pay attention to handle dimensions and screws suitable for the front thickness.
- Avoid simple adhesive handles, as their durability suffers with frequent use.
I have had very good experiences with handles from hardware stores that are actually intended for kitchen fronts. If you like, I can suggest a few models that work well.
Hope this helps you for now!
Cecilera66
8 Jan 2020 11:05
I have had very good experiences with small, round wooden knobs from Platsa. They are easy to install and create a warm atmosphere without disrupting the minimalist style. Of course, the screw length needs to be appropriate.
Lucki
9 Jan 2020 08:13
- Metal handles with a simple, clean design (e.g., bar handles or rounded knobs) that complement the minimalist look of Platsa.
- Alternatively, matte aluminum or brushed steel handles that are not too shiny, to maintain the Scandinavian/minimal style.
Great tip! I specifically got a set made of brushed stainless steel and I'm very satisfied. It not only looks elegant but also feels high-quality. It really adds value to Platsa and is far from boring.
Don’t be afraid to be a bit bolder with the handles; it really makes a difference! 🙂
RENMA
9 Jan 2020 14:49
In addition to the points already mentioned, I recommend ensuring compatibility between the chosen furniture handles and the type of front used for IKEA Platsa (painted, foil, melamine), as different materials require different stress tolerances and drilling specifications.
Handles with a screw length of approximately 15-20 mm (0.6-0.8 inches) have proven to be the most suitable for securely attaching the thin fronts without risking damage.
A clear, geometric design style fits Platsa both functionally and aesthetically, so classic, simple bar handles or small knobs with a matte finish are preferable.
Furthermore, the handle position should be selected to ensure user comfort, which is especially important for lower drawers.
Leonardteo
10 Jan 2020 09:54
REOLAU33 schrieb:
Are there any furniture handles that are particularly recommended due to their material, shape, or color to enhance the look of Platsa cabinets while also improving usability?
In my opinion, there is no single best solution, as it always depends on personal style and how the furniture will be used.
That said, matte metal—especially aluminum or brass with clean lines—works very well with Platsa.
I also find that high-contrast colors are effective if you want the piece to stand out as a focal point.
If tactile feel is important to you, rounded knobs made of wood or metal are advisable.
The most important tip is to choose the fasteners carefully to match the panel thickness in order to prevent damage.
