I am about to assemble an Ikea Brimnes carcass with drawers, but I have already read several reports that the assembly can be somewhat tricky, especially when it comes to the drawer slides and aligning the fronts. Therefore, my question is: Are there any assembly tips or special tricks for putting together the Ikea Brimnes that one should definitely know to save time and avoid mistakes? Perhaps someone has experience with this piece of furniture and can share advice on the best approach, choice of tools, or common pitfalls. Thanks in advance!
I can share some precise tips to make assembling the Ikea Brimnes easier:
- Use a cordless drill with adjustable torque to avoid overtightening the screws, as the panels are quite thin.
- Start by assembling the side panels and the back panel to create a stable frame.
- For the drawers, it is important to align the runners precisely. A spirit level or at least a flat surface is recommended for this.
- Attach the fronts last; before tightening the screws, double-check the fit of the drawers, as small adjustments are easier to make at this stage.
These points help reduce effort and frustration during assembly.
Hello Praleo,
I assembled the Brimnes wardrobe myself at home. Your question about the installation is very relevant, and I would like to explain it in more detail.
In my experience, it is important to carefully follow the instructions step by step without rushing. Most mistakes happen when trying to do several steps at the same time.
Regarding the drawers: The runners are delicate and require some patience when inserting. If the drawer does not slide smoothly, you should check if:
- the runners are aligned parallel and level
- no screws are overtightened
- the drawer bottom is properly seated and not stuck
Sometimes it also helps to assemble the parts loosely first and only tighten all screws afterwards to avoid tension.
I hope this helps you!
I would like to add and clarify some common mistakes when assembling the Ikea Brimnes:
- Do not fully tighten screws right away: They should first be screwed in just enough by hand, then you align the parts, and only tighten completely at the end.
- Always attach the back panel last: This helps maintain some flexibility when aligning the unit.
- Lightly grease the drawer runners: A small dab of silicone grease on the sliding rails prevents squeaking and makes closing easier.
Typical mistakes I have seen:
- Mixing up the side panels (although they are usually well marked)
- Ignoring the correct screw length in sensitive areas (to avoid puncturing the thin material)
In summary: Work patiently, plan the assembly calmly, and pay attention to details.
LAURE-TA schrieb:
Apply a light lubricant to the drawer slidesI can confirm that. Additionally, make sure the drawers are not loaded too heavily, otherwise the slides may shift over time.
