ᐅ Are there any tips to make installing Pax wardrobes easier?
Created on: 28 Jul 2024 18:37
Myronlo
Myronlo
28 Jul 2024 18:37
Hello everyone, I am planning to assemble the Pax wardrobe at home soon. Since I have read that the assembly can be quite challenging due to the large number of parts and sometimes unclear instructions, I wanted to ask the community: Are there any tips or tricks to make assembling the Pax easier and more efficient? I already have basic experience with furniture assembly, but I am especially interested in how to avoid common pitfalls. For example, are there proven sequences, special tools, or organizational methods that can significantly simplify the process? I look forward to your experiences and advice!
dijan
28 Jul 2024 19:05
Hey Myronlo, great question! I assembled the Pax last year and can share a few tips that really make a difference. First of all: take your time – rushing furniture assembly is usually the biggest enemy. 😅
A handy trick is to spread out all the parts and screws on the floor, preferably in small bowls or containers, so you don’t have to search forever. Also, it’s worth not just following the instructions step by step, but first skimming through them completely to get an overview of the process.
I had a good experience using a cordless drill with adjustable torque; it tightened the screws to the right level – not too tight, not too loose. Oh, and when installing the back panels, matchsticks or small wooden blocks can be helpful to position them precisely and straight.
It might all sound simple, but it really makes the process easier. Good luck with the assembly!
Jensson
29 Jul 2024 07:42
dijan schrieb:
Take your time – rushing during furniture assembly is usually the biggest enemy.
I completely agree. Additionally, here is a simple step-by-step guide that works well in practice:
- Group all parts by category (e.g., side panels, boards, screws)
- Clear the workspace in front of the cabinet thoroughly
- Prepare your tools: cordless drill, screwdriver, hammer, spirit level
- Skim through the entire instructions before starting with the first step
The most important thing is the correct sequence: install doors and drawers last; otherwise, you’ll make access to the screw points much harder.
Common mistake: assembling parts directly from the packages without spreading out and organizing everything first.
If you have a partner, handling the larger parts is much easier, especially the cabinet sides and carcass. One last tip: if something is unclear, always carefully compare the side numbers and drill holes to avoid mix-ups.
I hope this helps!
Gloriagl10
29 Jul 2024 12:18
Myronlo schrieb:
Are there any tricks or helpful tips to make assembling Pax easier and more efficient?
Yes, always start by loosely fastening all screws, then tighten them fully at the end. This helps avoid alignment issues during assembly.
Maria35
30 Jul 2024 10:13
Jensson schrieb:
Typical mistake: Installing parts directly from the packages without spreading them out and organizing.
This is a key point. From my experience, systematic preparation greatly simplifies the assembly process. Additionally, I recommend:
- Using a magnetic screwdriver to prevent losing screws
- Maintaining a tidy work area for quick orientation
- Using a spirit level to ensure the main structure is aligned correctly
It is also essential to check all parts for completeness before starting. Smaller screws or connectors are often overlooked, which can cause interruptions later on.
These steps enable a controlled and efficient workflow, especially for more complex furniture like Pax.
