ᐅ Are there any tips for cleaning Ikea Hemnes furniture when you have pets?
Created on: 19 Jan 2021 18:43
Lucegi
Lucegi
19 Jan 2021 18:43
I have a question specifically about cleaning Ikea Hemnes furniture when you have pets. My situation is that I have several animals at home (one cat and two dogs), and they sometimes cause stains, scratches, and animal odors. Of course, I want to avoid damaging the natural wood of the Hemnes series while keeping everything hygienically clean.
Could you share tips on which cleaning products are suitable to protect the wood and surface without harming the pets? Are there any pet-friendly home remedies or special products I can use to effectively remove stains and odors?
I would appreciate any expertise, including advice on regular maintenance that benefits the furniture without damaging the delicate surface.
Thank you in advance!
LANICOLE
19 Jan 2021 19:12
Hello Lucegi,
First of all, it’s great that you’re considering the combination of pets and Hemnes furniture, as that can indeed be tricky.
Here are some structured tips for cleaning and care:
- Cleaning: Use a mild soapy solution (about a few drops of neutral dish soap in warm water) and soft cloths. Avoid harsh chemical cleaners or alcohol-based products, as they can damage the wood.
- Stains: For fresh stains, a slightly damp microfiber cloth with some dish soap works well. For stubborn stains, you can carefully treat the area with fine sandpaper (e.g., 280 grit) and then reapply oil or wax.
- Odors: Baking soda is ideal for absorbing odors. Simply sprinkle some on the affected areas, leave it for a few hours, then brush it off.
- Protection: Regular application of furniture wax or care oil protects the surface against scratches and creates a water-repellent layer. This is especially important if pets jump onto the furniture when wet.
- Prevention: It’s best to place washable covers on frequently used surfaces to minimize direct skin, fur, or saliva contact.
I hope these tips are helpful. It’s important to always test on an inconspicuous spot first to see how the wood reacts.
If you need more details or want to share your experiences, feel free to get back!
tinau
19 Jan 2021 19:27
I clean Hemnes furniture used around pets with lukewarm water and a mild soap. I avoid harsh chemicals because they can damage the furniture and harm the animals. For stains, I gently wipe with a damp cloth and neutralize odors with baking soda.
angel
20 Jan 2021 07:58
Hi Lucegi,
I understand that furniture maintenance can be particularly challenging when you have pets. I have a cat myself, and my advice is to dust regularly and avoid cleaning the furniture with too much water, as the Hemnes wood can swell otherwise.
LANICOLE schrieb:
Avoid aggressive chemical cleaners or alcohol-based products, as they can damage the wood.
I can confirm that. From my experience, use only mild dish soap and wipe it off immediately with clean water. For light stains, I gently sand the area as LANICOLE suggested, then apply furniture oil afterwards.
Also, regularly checking for scratch marks helps prevent them from becoming deeper.
For odor removal: besides baking soda, a few drops of lavender essential oil mixed with water can be used for wiping — pets like the scent and it has a calming effect.
My recommendation is to find the right balance between gentle cleaning and preventive care to keep your Hemnes furniture looking good while protecting your pets.
Gregory
21 Jan 2021 11:36
Summary and precise tips for cleaning Ikea Hemnes furniture when living with pets:
- Use only mild cleaning agents, such as neutral dish soap in warm water.
- Avoid alcohol-based, acidic, or other harsh cleaners that can damage the wood.
- For stains, use a damp cloth; for more stubborn dirt, gently sand the area and then apply care products.
- To protect against scratches and moisture, regularly apply furniture wax or care oil.
- Baking soda is effective for odor absorption and removal, as it is non-toxic and leaves no residue.
- Essential oils can be used additionally, but please ensure they are safe for pets.
This approach ensures the preservation of Hemnes furniture while maintaining hygiene around pets. Regular cleaning and care significantly extend the furniture’s lifespan.
I strongly recommend testing cleaning agents first on an inconspicuous spot and consistently following protective measures.
