ᐅ Are there any tips for assembling Malm furniture without mistakes?
Created on: 24 Jan 2023 18:37
LutyrellAre there any specific tips or proven methods for assembling a Malm desk or a Malm drawer chest to avoid common mistakes? I understand that the IKEA instructions are generally clear, but I would like to benefit from the experience of other users. I’m especially interested in advice on how to avoid typical pitfalls during assembly, which tools are really helpful, and if there are particular points where you need to be very careful to ensure everything ends up stable and flush. Are there also any tricks on how to prevent screws from misaligning or parts from being damaged by applying too much force? I have some experience, but with larger furniture pieces, I always feel a bit uneasy that something might not fit properly or be wobbly in the end. Thanks in advance for your tips!
I can well understand your uncertainty—I felt the same way the first time I assembled Malm furniture.
One trick that really helped me was to check all the wooden parts for damage before even starting to screw anything together. If a piece already has a crack or an imperfect edge, it’s often difficult to compensate for that during assembly.
Also: it’s better to screw in the screws by hand just enough at first, and tighten them fully at the end. This helps avoid misaligned screws and damage to the material. I also find that a good Allen key with longer leverage makes this easier than the short IKEA tools. A simple torque wrench is of course a luxury, but just using a feel for it usually works fine.
Hope this helps you! 🙂
Lutyrell schrieb:– for me, that was mainly about properly sorting all the screws and parts before starting. If you get mixed up there, it’s easy to lose track and confuse components.
I'm especially interested in tips on how to avoid common pitfalls during assembly
draFrederi24 Jan 2023 21:05elgla schrieb:
It’s better to screw the screws in just hand-tight at first and only fully tighten them at the end Exactly! 🙂 I’m also a fan of taking your time and not rushing. I always find it helpful to say out loud, step by step, what to do next – that way you keep track of everything and make fewer mistakes.I also recommend temporarily assembling the furniture piece “dry” before fully screwing it together. This way, you can quickly see if everything fits or if adjustments are needed, without tightening the screws right away.
And one more tip: build on a hard surface – not on carpet or uneven ground. This makes it much easier to align the parts accurately during assembly.
Have fun and don’t worry, you’ll manage it! 🙂
Here are some structured tips for assembling the Malm furniture, based on my experience and common mistakes:
1. Preparation:
- Unpack all parts and spread them out on a large, clear surface.
- Sort screws, dowels, and fittings by type, preferably into small containers or bowls.
2. Tools:
- In addition to the IKEA Allen key, use a good hex key with a handle for precise and controlled work.
- A cordless screwdriver can help, but only at low speed and with care to avoid damaging the material.
3. Assembly:
- Always start with the main components and follow the instructions carefully.
- Insert screws only slightly at first; check all connections before fully tightening.
- Pay special attention to aligning screws straight, otherwise they may cross-thread.
4. Common pitfalls:
- For Malm dressers, ensure correct alignment of the back panel—do not press it in too tightly, as this can make the furniture unstable.
- For the desk, carefully check the alignment of the tabletop, as small deviations can cause wobbling later.
5. Final steps:
- Once everything is screwed together, check the stability and retighten screws as needed.
In short, patience and careful work are key. If you’re unsure, it’s worth asking a second person for help—not only to hold parts, but also to provide an objective perspective.
If you want, I can provide more detailed tips if you tell me which furniture piece (desk, dresser, etc.) you’re assembling.
1. Preparation:
2. Tools:
3. Assembly:
4. Common pitfalls:
5. Final steps:
