ᐅ Are there any tips for installing IKEA PLATSA units in older apartment buildings?
Created on: 25 Sep 2024 08:23
dinfu
Hello everyone, I am currently planning to install the IKEA Platsa system in my older apartment and have come across some challenges that I want to examine more closely beforehand. My main issue is the often uneven wall surfaces and partly crumbly plaster, which complicate the secure mounting of the PLATSA units to the walls. Additionally, the fact that many older walls are made from different materials such as plaster, stone, and sometimes wood paneling makes the installation less straightforward.
My question is therefore: Are there any practical, proven tips or methods specifically for older apartments when installing IKEA PLATSA that ensure the units are stable and durable without damaging the historic building fabric? I am also interested in whether particular types of wall plugs, mounting kits, or alternative fastening techniques are recommended.
I look forward to any experiences, advice, or additional questions to approach this topic comprehensively.
dinfu schrieb:
Are there any proven practical tips or methods specifically for installing IKEA PLATSA in older apartments that ensure the units remain stable and secure over time without damaging the historic building structure?Basically, I recommend always checking the inherent stability of the PLATSA units and using as many fixing points as possible when mounting them on the wall. Especially in older buildings, some wall areas can be slightly flexible, so a single strong screw might not hold for long.
A few tips I often use myself:
- Purchase appropriately sized anchors before installation (metal or chemical, depending on the situation)
- Use large wooden wedges or spacer blocks to compensate for uneven wall surfaces
- Drill slowly, always with the correct masonry drill bit and without hammer function on soft plaster
- Use a drill with adjustable speed control for drilling and screwing
I understand your concern about preserving the historic building fabric. That’s why you should avoid oversized holes or unnecessary over-drilling. A well-installed chemical anchor will leave hardly any visible marks if you ever remove the furniture.
Combining this with screw-on leveling profiles behind the PLATSA units can further improve load distribution. If you like, I can offer you some suggestions on that.
