Hello everyone, I am planning to buy an IKEA Hemnes bed soon, but I find the assembly somewhat complicated. Are there any proven tips or methods that make the setup easier? I feel that some steps in the instructions are not entirely clear, especially regarding the alignment of the individual parts and the screwing process. Does anyone have experience with common pitfalls or valuable advice to avoid mistakes? I would appreciate detailed tips, especially on how to effectively use tools or aids. Thanks in advance!
Hello Alpay, I have assembled the Hemnes bed several times and would be happy to help you. It is important to first sort all the parts and check that all screws and wooden components are included. During the assembly itself, I strongly recommend following the instructions step by step and only tightening the screws by hand at first, before properly aligning everything and then fully tightening them afterwards.
This is often the tricky part, since the bed consists of several elements that need to fit together as straight and flush as possible. When putting everything together, it is best to use a spirit level or ruler to ensure proper alignment. The supplied Allen key is usually sufficient as a tool, but an electric screwdriver with adjustable torque makes the screwing process much more comfortable. If you have any more questions, just get in touch!
Alpay schrieb:
I have the feeling that some steps in the instructions are not entirely clear, especially regarding the alignment of the individual parts and the screwing.
I would like to add some structured tips that helped me when assembling the Hemnes bed:
- Carefully inspect all parts before assembly; any damage could cause problems later.
- When attaching the side panels, pay close attention to the correct orientation of the elongated hole openings, as these are where the slatted frame holders are secured.
- Use protective layers like blankets or rugs to prevent scratches on wooden parts during assembly.
- When screwing the bed sides together, first tighten all screws lightly to ensure proper alignment before fully tightening them.
- Don’t skip the step of checking if the bed is level before installing the slatted frame.
That’s a very valuable tip! One more point: if you want, you can check the slats of the slatted frame; many can be replaced with stronger ones if you want more comfort. Hope this helps.
Jeanbar schrieb:
If possible, use a spirit level or ruler during assembly to make sure everything is properly aligned.
Rashadmeo3 Nov 2022 07:37Hey Alpay! I really like the design of the Hemnes bed, even though it seems tricky at first! 🙂
My advice: Take your time, open one box at a time, and sort the screws separately. This will save you a lot of time and frustration later.
I also laid out all the parts on a large surface before starting to assemble. This way, you can see everything at once and look forward to the result!
And most importantly: Have fun with it—that makes the whole process much easier! If you get stuck, just reach out, and we’re all here to help!
For additional clarification: The IKEA Hemnes bed primarily uses connector fittings that must be positioned precisely to ensure stability. When inserting the wooden dowels, make sure to maintain the correct insertion depth, as inserting them too deep or too shallow can affect the fit.
The supplied Allen wrench is sufficient in terms of tools, but using a torque wrench is recommended to avoid over-tightening the screws.
Additionally: For the final tightening, ensure the bed is on a stable surface to avoid deformation. Carefully check the positioning of the slatted bed base holders, as they directly bear the weight.
Jeanbar schrieb:
The included Allen key is usually enough, but an electric cordless screwdriver with torque control makes the screwing work much more comfortable.
