ᐅ Are there any recommendations for maintaining IKEA Hemnes furniture in humid conditions?
Created on: 18 May 2023 08:23
luisriHello everyone, I have a question regarding the care of IKEA Hemnes furniture, specifically when dealing with increased humidity in living spaces such as kitchens or bathrooms without direct water contact. Are there any recommendations on how to treat the Hemnes collection to help the furniture maintain its stability and appearance for as long as possible despite the moisture in the air? I am particularly interested in whether any special care products are recommended or if there are effective methods to prevent moisture damage without harming the surface. I would appreciate any tips on cleaning, maintenance, and possible protective measures.
Hello! Your question is very well formulated and important, as the Hemnes series is traditionally made from solid pine wood, which can be sensitive to moisture. Here is a brief guide for caring for it when exposed to moisture:
- First, you should avoid water directly coming into contact with the surface. High humidity can also cause the wood to swell.
- Regular ventilation of the rooms is essential to keep the humidity level within the normal range (around 40-60%).
- For cleaning, use a slightly damp cloth that is immediately wiped dry. You should definitely avoid harsh or alcohol-based cleaners.
- To protect the surface, special wood care products for lacquered or oiled finishes are recommended, depending on which finish is applied to Hemnes. IKEA usually uses clear lacquer, which can be refreshed with mild furniture oil or wax to maintain the protective layer.
- If you want to be extra cautious, you can treat the furniture with a breathable furniture wax that protects against moisture but does not seal the wood, allowing it to continue to “breathe.”
A small note: when furniture is placed in very humid environments, increased precautions are necessary to avoid warping or swelling. For example, furniture feet can be protected from floor condensation by using felt pads or plastic glides.
In summary: regular ventilation, gentle cleaning, and occasional use of care oil or wax. This way, Hemnes remains attractive and durable.
LEEJU schrieb:
Just ventilate regularly and don’t leave wet towels lying around. This is a very important point, thank you for adding it!
I would also like to add that, besides ventilation, the placement of Hemnes furniture in rooms with moisture is important: if possible, avoid positioning them directly next to radiators or walls that are excessively cold on the outside, as this can cause condensation on the wood.
Additionally, be careful when choosing care products: products containing solvents or silicone-based waxes can damage the surface or make later refinishing more difficult.
If the surface ever feels a bit rough or dull, ecological furniture wax or a little natural oil (such as linseed oil) can help restore the wood’s smoothness and repel moisture.
If you use the furniture near the kitchen, it is also advisable to regularly check for small scratches or damages, as moisture can often penetrate microscopic cracks there. Any necessary repairs should not be delayed to prevent further damage.
