Hello everyone, I am thinking about simple DIY ways to customize the popular Ikea Hemnes shelves. I am especially interested in techniques that don’t require much prior craftsmanship knowledge but still provide a lasting visual or functional improvement. For example, how to treat the surface to make the wood more durable or visually appealing, or if there are good ideas to make the shelves more stable or flexible with minimal effort. Does anyone have experience or tips they can share? I look forward to concrete and easy-to-apply suggestions for DIY modifications to Hemnes shelves.
Basically, sanding the surface is the most important step if you want stain or oil to properly penetrate and adhere long-term. When choosing a product: linseed oil or special wood oils for furniture work well because they nourish the wood and don’t bead up quickly. Very important – always test a small area first.
For fastening the angle elements: gluing is possible with two-component epoxy resin adhesive or construction adhesive, but it is never as strong as mechanical screwing. If you don’t want to drill through holes, small screws on the inside through the back panel might be more practical.
Regarding the back panel: plywood has a nicer texture and is more stable compared to hardboard, especially for large surfaces. It also provides more stability, while thin hardboard panels tend to warp more easily.
Muso4 schrieb:
Why always change the surface? The HEMNES shelf is designed to be much too plain and conservative. I find the comment a bit exaggerated. The simple design is actually what many appreciate – it allows for easy modifications without altering the overall look. Radical alterations often limit reusability and flexibility. Sustainability should be a consideration as well, shouldn’t it?
An alternative to sanding and staining could be to use self-adhesive films to add accents that do not cause damage and can be removed at any time.
Interesting thread! I wonder how much these DIY tips actually affect the durability of the shelves. You often see great ideas that, however, compromise the stability of the furniture. Are there any long-term experiences on whether applying varnishes or oils, for example, still protects the surfaces after several years, or if the material tends to deteriorate instead?
I would also be interested to know if users have ever made modifications to their shelves that later turned out to be mistakes – this could help all of us avoid common pitfalls.
Addressing the specific questions: In general, oils and stains help make the wood more resistant to moisture and minor scratches. If you are starting fresh, you should sand off the old finish as thoroughly as possible, ideally with 180-grit sandpaper, to create a smooth base.
Regarding stability: The Hemnes shelf is fundamentally sturdy, but you can reinforce the structure at specific points using simple clamp brackets or self-adhesive metal brackets without drilling. Adhesive bonds hold well if the surfaces are free of grease and the material is firmly held in place while the adhesive cures.
Long-term experience: Many users report that sealed surfaces are less vulnerable as long as no major mistakes were made during painting or oiling.
