I am currently working on assembling Malm furniture and wonder if there are alternative tools I can use instead of the usual screwdriver or cordless drill. My main concern is achieving faster and more precise assembly without damaging the screws or the furniture parts.
Are there any special tools or aids that have proven effective in practice, especially for Malm dressers or cabinets from IKEA? Maybe someone has experience with alternative assembly aids that make the process easier or improve it?
Thanks in advance for your tips and suggestions!
Max43 schrieb:
Are there any special tools or aids that have proven practical, especially for Malm dressers or IKEA cabinets?In general, I recommend using a cordless screwdriver with a torque limiter when assembling Malm furniture. This prevents screws from being overtightened and damaging the wood.
As an alternative to standard Phillips bits, there are so-called Torx bits, which provide a better grip and are gentler on the screws. Additionally, angle attachments make it easier to work in tight spaces.
I also find small rubber mallets helpful when dowels need to be inserted precisely without damaging the wood.
In my view, these are the most important tools that are often underestimated.
PULAU schrieb:
A cordless screwdriver with a torque limiter prevents screws from being overtightened and damaging the wood.I can only confirm that. I used to have frequent problems with screws slipping or the screw heads stripping, which was really frustrating.
What also helped me is a good bit holder with a magnetic function. This way, the screws don’t keep falling off, especially when you’re working alone.
Personally, I was unsure at first whether these extra tools would really make a difference, but after a few assembly tasks, the work feels much more relaxed. The time you save from fumbling around is truly priceless!
How about you? Does assembly feel noticeably less stressful with the right tools?
Max43 schrieb:
Are there any special tools or aids that have proven useful in practice, especially for Malm dressers or cabinets from IKEA?I tried something out: instead of just using the classic cordless drill, I used a small, handy ratchet attachment. It gives the feeling of gently and precisely driving the screw in without over-tightening—a real advantage for IKEA furniture, which often consists of thinner MDF panels.
And because I like to keep it simple, I usually use so-called "bits" with an ergonomic handle for manual fine work. Sometimes you need the power of a cordless drill, sometimes just a delicate touch.
By the way, a tip: if you need to make minor adjustments, self-adhesive mounting clips or connector fittings often complement regular screwing quite well.
Well, it might sound a bit nerdy, but I’d say: working calmly makes the finished furniture more enjoyable in the end. 😊
