ᐅ Are there alternative sets of rollers for the Kallax that are more durable?
Created on: 4 May 2020 18:27
FISO65
I have a question that might also be interesting for some of you: Are there alternative caster wheels for the IKEA Kallax shelf unit that are more durable than the original ones?
I use the Kallax in my workshop and find the supplied wheels somewhat wobbly and prone to issues—especially when it’s loaded with heavier items or when I need to move the shelf on uneven floors.
Therefore, I’m interested in high-quality replacement casters that are not only more stable but also longer lasting. Does anyone have experience with specific brands or modifications that you would recommend?
I would also appreciate advice on the best way to replace the wheels, in case the process is a bit complicated.
Thanks in advance for your tips and opinions!
FISO65
5 May 2020 08:16
GUSTAVO56 schrieb:
I would also like to know: What are the loads, how often do you move the shelf, and on what type of floor?
Thank you very much for the detailed explanation!
I mainly load the shelf with tools, materials, and electronic components, estimating the weight at about 25-30 kg (55-66 lbs) per section (I have a 4x4 Kallax). It isn’t moved daily, but maybe 1-2 times per week, mostly on laminate flooring, which is quite sensitive.
The ability to move the shelf easily when needed is important to me – tile flooring in the basement is also an option, but ideally the floor should be protected.
If the rolling noise is low, that would be an additional plus!
How difficult is the conversion usually? Most casters are connected via a threaded spindle – could you simply screw on different ones?
rubybi
5 May 2020 09:45
Hello FISO65,
I’m happy to give you a step-by-step guide on how to replace the casters on your Kallax shelving unit:
1. Remove original casters: The original casters are usually attached to the Kallax base with an M8 threaded spindle. Use pliers or an appropriate wrench to unscrew them.
2. Select new casters: As mentioned before, casters with an M8 threaded spindle are best suited so you don’t have to drill any holes. Make sure each caster can support at least 40 kg (88 lbs) and has a polyurethane or rubber tread suitable for laminate flooring.
3. Installation: Simply screw on the new casters and tighten them securely. Make sure the threads engage properly and the casters sit straight.
4. Check: After installation, gently tilt the shelving unit to test the caster balance. You may need to adjust the casters slightly.
Common mistakes when replacing casters:
- Using casters with the wrong thread size (which may not fit or hold properly)
- Drilling holes in the Kallax shelving unit for other mounting methods that are too large or incorrectly positioned
If you want, I can also recommend specific sources to purchase the casters.
Alberto51
5 May 2020 10:58
This is truly a topic that affects many here!
I completely understand the need for sturdier casters. I have often felt like I didn’t want to move the shelf at all because the casters were so weak and squeaky.
LENNAU schrieb:
If you need help choosing or installing, feel free to ask!
I really appreciate offers like this because it’s easy to get overwhelmed when you consider that the right casters have to match both the shelf and the floor, plus the installation needs to be done properly.
My advice to everyone: if you’re unsure, buy something “better” with a higher load capacity and look for a non-slip tread. This is especially important on laminate flooring to avoid scratches.
Who would have thought that such simple furniture involves so many technical details! 🙂
barle
5 May 2020 11:23
I installed TENTE chair casters with M8 threads on my Kallax. They hold very well and roll smoothly. Installation is simple, no drilling required.
